Here's a new one for you
   / Here's a new one for you #1
ByronBob
Byron New York
2004 BX2230
Here\'s a new one for you
I'm trying to mow with my Craftsman. I engage the deck and neither of the blades move. The belt is routed the correct way but the belt just spins in place. Could the belt be stretched out too far to work.
Another question. Could the pulleys engage but possibly not far enough to put enough tension on the belt to spin the blades?
   / Here's a new one for you #2
Re: Here\'s a new one for you
You might look under the deck and see if something is wedged between the blades and the deck. Check the spindles to see if a bearing is seized. Maybe the belt is simply worn and stretched. One other possibility is that you sheared a key on the drive pulley.
The blades are free and I didn't think of the key. Belt could be stretched but wanted to rule all other things out first.
Where would the key be?
   / Here's a new one for you #4
Not certain on this particular model or anything so take this with a grain of salt....
Most times there is an idler pully tension spring and its end fastens somewhere on the frame or deck. It could not be fastend and therefore the belt is not staying tight. Often its a loop of chain that hooks into a notch. This has to be pulled into its notch to keep that idler pully tensioned.
   / Here's a new one for you #5
The key would most likely be on the motor shaft.
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2005 Wells Cargo CEW202 20ft T/A Enclosed Concession Trailer (A51694)
2005 Wells Cargo...
2003 Ford F-350 King Ranch 4WD Pickup Truck (A53117)
2003 Ford F-350...
2021 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A53843)
2021 ALLIANCE...
Adams Tender / Magnolia Trailer (A53473)
Adams Tender /...
Pickup Instructions (A47477)
Pickup...
