Here we go again... Flail Mower vs. Rotary cutter question... New England / upstate N
   / Here we go again... Flail Mower vs. Rotary cutter question... New England / upstate N #31
Good Lord - there must be someplace where rocks aren't the major crop. I mow about two acres around my house and out buildings. Two thirds of this is meadows. I mow with a new JD X570. It's taken two years but now I can mow it all and never hit a rock. A whole lot of digging - grunting - filling in holes. A new meadow I just cleared and began mowing last year.
   / Here we go again... Flail Mower vs. Rotary cutter question... New England / upstate N #32
Flails can't mow tall grass?
7' tall grass. No clumping. No wrapping up of/on the rotor. It's running hammers and it have knife/blade shredders. It wasn't my intention on using the flail this way, it was just a test. My intentions are for cutting such grass with my RC: most of the stuff for concern is easily 7' and higher by the time I'm able to get around to it (too wet to get it while it's shorter). I was quite pleased to find that I was able to tackle 4' to 5' tall grass w/o concern: more that I can get on the first mowing of the season with the flail makes the flail a bigger win for me (7' flail vs 6' RC; less passes means less turning, which means faster, though running the flail is a bit slower).
My flail picked up an 8" diameter chunk of wood and stopped it and the tractor cold: only time I'd ever experienced this (in some 650 hrs on this machine). No damage. I told the vendor about this and he said that the flail is NOT a forestry mulcher! Well, yes, I'm well versed in dealing with heavy brush and KNOW to use RCs in such instances, but this was one of those accidental encounters. My point here is that flails aren't necessarily fragile things. Are they more maintenance-heavy than RCs? Yes. Rock and stump mowers? Nope. I don't have rocks to contend with, nothing of size that presents any significant issue: rocks that might cause trouble are ones in known fill areas and they've all been tamed (not sticking up above the surface to present issues). In my use I'm unlikely to break a hammer: although the flail is new to me (this year/season), if I haven't broken a hammer up to now I'm unlikely to do so in the future.
My 6' RC has a 1/4" plate steel welded on the top. Previous (and only) owner used it commercially. It chewed through a TON of rocks (deck was blasted through)! Beat the snot out of it but it still does the job: I'll run it into anything w/o fear (flail, nope; but, the flail cost me about 3x the cost of my used RC, so I'm inclined to not get as daring with it).
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
2025 J & C Suppliers Enclosed Trailer (A56859)
2025 J & C...
2012 Ford F-550 Crew Cab Truck (A54814)
2012 Ford F-550...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2010 KENWORTH T800 (A58214)
2010 KENWORTH T800...
2014 INTERNATIONAL  DURASTAR 26FT BOX TRUCK (A58017)
2014 INTERNATIONAL...
