Here is what I learned from TBN
   / Here is what I learned from TBN #1
c-and-a
Massachusetts
BX2350
Ballast threads are abundant - so here is what I learned from TBN
Make is close - tight to the tractor
Don't make it top heavy
And always have a good dolly to make mount/unmounting easy...
It's a drain pipe left over from street work, cut down and filled witgh concrete, and a tool holder (4" pvc pipe) for good measure.
I estimate it weighs about 325# - but math was never my strong point.
   / Here is what I learned from TBN #2
Very intuative. :cool:
Now I'm just wondering if you could fill that pipe up with a liquid refreshment and plumb a long straw to the operator area. :D
Nice job. I like it!
Don
   / Here is what I learned from TBN #3
Cool!
   / Here is what I learned from TBN #4
That's just jim-dandy. Looks like a good 1 day spring project for me. Hope you don't mind me stealing your idea.
Pat
   / Here is what I learned from TBN #5
I can understand the need for ballast but just wanted to ask whether a rear mounted implement would serve the same purpose? Is this ballast setup heavier and/or more maneuverable? Just trying to learn :)
   / Here is what I learned from TBN #6
It should provide more ballast in a more compact size, than an implement hanging off the back.
Nice job c-and-a!
   / Here is what I learned from TBN #7
That looks good. :D :D :D
One the next one add a chain hook and ball hitch receiver.:D
A proper slot down the middle and it could hold a chainsaw too.:D
Thanks for the comments folks...
I have taken the MMM and Bagger off for the winter - so this takes up far less room in the rear allowing me to maneuver easier for the driveway clearing in the winter and it will assist in moving 20yds of mulch in the spring - again, lotsa of back and forth in tight areas...
Enjoy folks!
2001 STERLING WATER TRUCK (A50458)
2001 STERLING...
1999 CATERPILLAR TH82 TELESCOPIC FORKLIFT (A51242)
1999 CATERPILLAR...
Hesston 565T Round Baler (A50514)
Hesston 565T Round...
2015 CATERPILLAR 289D SKID STEER (A51242)
2015 CATERPILLAR...
UNUSED AGT MCMRT14 STAND ON SKID STEER (A51243)
UNUSED AGT MCMRT14...
5' X 20' 3/8" THICK STEEL PLATE (3) PIECES (A51244)
5' X 20' 3/8"...
