Herbicide help
/ Herbicide help #1
Rat Rod Mac
In the past I would crawl underneath multi-flora rose bushes and cut them off, then spray the cut stem with pure concentrated Tordon RTU. On larger stems I would use a cordless drill to actually drill a hole in the top of the stem and shoot a few drops in the drilled hole to kill these plants. Now it seems that Tordon RTU is getting hard to find ( E.P.A. I guess ), but Crossbow is still available. Would Crossbow do the job? Thanks for your help. RRM
/ Herbicide help #2
Cornell had a woodlot seminar recently recommended "Garlon" for cut stumps. I haven't checked into it yet, may be another option?
/ Herbicide help #3
I believe you could just Garlon 10E as strickly a basal treatment. That is, not cutting and simply spraying the stem. Should be able to do that 12 months a year (yes, even when dominant).
/ Herbicide help #5
i weed wack them ( i use a heavy duty string trimmer) and round up them. it knocks them out. big batches go in with pruners and cut them out and spray. good luck they are a pain.
/ Herbicide help #6
Meaning "dormant" as in the winter months??
/ Herbicide help #7
We have been fighting them for years as a neighbor had originally planted them on his farm across the road as the MO Dept of Conservation was then touting them as a living fence that was good for wildlife. Crossbow as a foliar spray works good when there is good moisture for them to be growing and I would say between 75 and 85 degree temperatures. Wet the whole bush and it will get them and not kill grass around them. We have also used SPIKE pellets when the rose bushes are far away from trees or other plants we want to keep. You can keep them in check but, if even 1 person next to your land does not, it will be a constant battle. Good Luck
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
INTERNATIONAL 4900 GRAIN TRUCK (A63291)
INTERNATIONAL 4900...
2005 Ford F-150 Ext Cab Pickup Truck (A61573)
2005 Ford F-150...
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
