herbicide dye marker
/ herbicide dye marker #1
pokerboy57
John Deere 3320
I want to find a blue or other color dye to add to the gallons of roundup I spot spray for weed control. anybody what this dye is ? I tried food coloring and it doesn't work. What is it that they us on golf courses ?
/ herbicide dye marker #2
/ herbicide dye marker #3
Farm supply dealers like Tractor Supply, etc., carry the stuff. I usually also add a contact surfactant (it's probably just liquid detergent :D) that helps the spray stick to the foliage. This seems to help with certain weeds whose leaves tend to shed water droplets (poison ivy, for example).
/ herbicide dye marker #4
Most farm & home type stores will carry that type of dye. Grandad4 is correct about the surfactant helping with some types of weeds.
and now I know. Thanks everyone for your replys.
/ herbicide dye marker #6
The dye will help you see where you have sprayed, but be forewarned, you will have it all over you... shoes, hands, etc.! If you ever spill even a small amount in a toolbox it will continue to show up on things for a long time... it is so concentrated that just a drop will make a big stain when water, sweat, etc. hit it. No matter how careful I was with the stuff, it still showed up when I didn't want it to... got to the point I quit using it. I know many will laugh at this post, but I bet many others can relate to what I'm saying!
/ herbicide dye marker #7
I originally used the marker dye that TSC sells ....... but it was expensive (around $20/QT)
Here's what I switched to, based on a suggestion from fellow TBN'er Pineridge, who has a pond:
Blue Bayou Pond Colorant
Treats up to 1 1/4 million gallons ..... :laughing:
/ herbicide dye marker #8
I have used these guys. I have had blue and now on a red kick...
By the way, mixing red and blue gives you a yucky purple that can't be seen on the foliage.
Solarogen, LLC :: Marker Tints
/ herbicide dye marker #9
Yep. Fortunately, it's water soluble and fades fairly quickly also. I like to use neoprene gloves and I'm not too fussy about measuring the dye to the nearest gram so there's less opportunity for me to make a mess. Rinsing the tank is another story, though.
/ herbicide dye marker #11
:laughing: :laughing: We are Laughing :laughing::laughing: cause we've been there and done that! :laughing::laughing:
/ herbicide dye marker #12
Old thread... Does the marker dye or pond dye stain plastic? I have a yellow atv that I'm going to use to spray with and I'd hate to have plastic stained.
/ herbicide dye marker #13
Generally yes.
/ herbicide dye marker #14
Hmm, I disagree, I spray herbicides out of an ATV everyday, as long as you wash off your machine when finished it shouldn't be a problem. If you get herbicide marker dye it will photo degrade over the course of a few days, not sure of the pond dye. More than likely the thing that will stain your plastic is the actual herbicide or any surfactants you add.
/ herbicide dye marker #15
Some herbicides will stain, even without any dye in them.
Prodiamine, and Prowl, two I use a lot, both stain plastics yellow.
Hydraulic Pump (A65640)
Hydraulic Pump...
Gehl RS6-34 (A64119)
6ft. 3pt. Blade (A65640)
6ft. 3pt. Blade...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
