herbicide dye marker
   / herbicide dye marker #1
pokerboy57
John Deere 3320
I want to find a blue or other color dye to add to the gallons of roundup I spot spray for weed control. anybody what this dye is ? I tried food coloring and it doesn't work. What is it that they us on golf courses ?
   / herbicide dye marker #2
   / herbicide dye marker #3
Farm supply dealers like Tractor Supply, etc., carry the stuff. I usually also add a contact surfactant (it's probably just liquid detergent :D) that helps the spray stick to the foliage. This seems to help with certain weeds whose leaves tend to shed water droplets (poison ivy, for example).
   / herbicide dye marker #4
Most farm & home type stores will carry that type of dye. Grandad4 is correct about the surfactant helping with some types of weeds.
and now I know. Thanks everyone for your replys.
   / herbicide dye marker #6
The dye will help you see where you have sprayed, but be forewarned, you will have it all over you... shoes, hands, etc.! If you ever spill even a small amount in a toolbox it will continue to show up on things for a long time... it is so concentrated that just a drop will make a big stain when water, sweat, etc. hit it. No matter how careful I was with the stuff, it still showed up when I didn't want it to... got to the point I quit using it. I know many will laugh at this post, but I bet many others can relate to what I'm saying!
   / herbicide dye marker #7
I originally used the marker dye that TSC sells ....... but it was expensive (around $20/QT)
Here's what I switched to, based on a suggestion from fellow TBN'er Pineridge, who has a pond:
Blue Bayou Pond Colorant
Treats up to 1 1/4 million gallons ..... :laughing:
   / herbicide dye marker #8
I have used these guys. I have had blue and now on a red kick...
By the way, mixing red and blue gives you a yucky purple that can't be seen on the foliage.
Solarogen, LLC :: Marker Tints
   / herbicide dye marker #9
Yep. Fortunately, it's water soluble and fades fairly quickly also. I like to use neoprene gloves and I'm not too fussy about measuring the dye to the nearest gram so there's less opportunity for me to make a mess. Rinsing the tank is another story, though.
   / herbicide dye marker #10
Ha, that looks like my hand a few weeks ago..Like ...Chevy chase in airplane toilet..
2015 PETERBILT 389 TRI-AXLE(INOPERABLE) (A45046)
2015 PETERBILT 389...
Chery 14' Bi-Parting Iron Gate (A44502)
Chery 14'...
2013 Nissan Pathfinder 4x4 SUV (A42744)
2013 Nissan...
Walk-Behind Brush Cutter (A44572)
Walk-Behind Brush...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A44572)
2017 Ford F-150...
2015 Ford Explorer AWD SUV (A42744)
2015 Ford Explorer...
