HENROB DHC 2000 COBRA WELDING/CUTTING TORCH
   / HENROB DHC 2000 COBRA WELDING/CUTTING TORCH #21
Jesse masterson said:
you can get a ac dc unit called Eastwood carried by the company jets for thin Alum only for around 900$
Everlast also has a unit in that price range but gas and supplies will cost extra. Hard to start tig welding of aluminum for less than $1500 initial outlay.
   / HENROB DHC 2000 COBRA WELDING/CUTTING TORCH #22
Having said this I can't believe the cost of Gas Cylinders over here..... As far as I know I can only rent the cylinders. And even the smallest ones cost $600 in the first year then $300 each year after.... +$12 a refill..... Can anyone tell me a cheaper way to do this?
That's a complete ripoff.
Since you are doing art, consider brazing using propane and a used medical oxygen concentrator. You can also use the torch to heat and bend. IF you get a concentrator which FILLS medical cylinders, you can do some cutting with them.
The Home Machinist! • View topic - Oxy/Propane - The Poor Man's Substitute
Portable Oxy-Propane setup. - Ford Truck Enthusiasts Forums
For steel art, buy a MIG.
If you make enough money or have it handy already, pay the nice man and get a TIG or a MIG suitable for aluminum. The custom Down Under (from what I've read in various forums) is to use short MIG guns with teflon liners instead of spool guns for aluminum MIG, so no reason that shouldn't work for you.
   / HENROB DHC 2000 COBRA WELDING/CUTTING TORCH #23
Not sure if it was said clearly or not but Mig on thin aluminum is difficult at best. Before you set up to do that, make sure you have tried it on the material you will be working on.
I went and looked at mine, it is a Henrob box and the torch itself said Dillon. I did notice a cd in there so maybe that demo video is there, I will check.
(INOP) 2005 BRODERSON IC80-3G 9 TON ROUGH TERRAIN CRANE (A51406)
(INOP) 2005...
2016 Ford F-150 4x4 Pickup Truck (A55852)
2016 Ford F-150...
2014 CATERPILLAR 305E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
SELLICK S60J4I-2 ROUGH TERRAIN FORKLIFT (A52705)
SELLICK S60J4I-2...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
