help
/ help #1
billsanfilippo
ford 800 kubota L3400
Not sure if one thing has anything to do with the other , but I will include everything-Parked my Ford 850 gas tractor after grading the drive two weeks ago. Ran fine-no problems. This tractor does not smoke or use oil. Went to use again and it cranked for 3-5sec without starting-always starts within a revolution or two. Looked in gas tank and appeared empty-checked with a stick and it was dry. Added some gas and attempted to start again. Cranked a few secnds and then battery died-never before a problem-put batt on charger for 3 hrs cleaned everything and replaced. Tractor started right up as usual. When I touched the steering wheel fluid squirted out about 3 feet near the power steering pump. Thought I blew a hose. Couldn't see any breaks so I removed the pump belt and started the tractor again. Same results-oil spewing every where. Now I could see it coming out of thr breather cap with such force it was bouncing off the block and spaying around. I checked the breather on the valve cover, and it was not clogged. I realize that some blow by is common as rings wear-but I can't grasp going from no problem to immense problem after sitting for 2 weeks. The baffle in the filler tube is in place. It is OK at idle-starts to spew at 1000rpm and at PTO speed is dumping a qt a minute. I ran it a total of maybe 2 minutes checking it and i was down 2 qts-over the years I have never had to add oil between changes. Does not appear to be antifreeze in the oil-the oil pressure is normal-I have not done a compression check yet, but it runs smooth not like a cyl or 2 is not firing. Not sure where to start looking???? Any advise will be appreciated Thanks, Bill
/ help #3
Check your hydraulic fluid level. If a seal fails in the hydraulic pump some tractors can dump hydraulic fluid into the crankcase.
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
Trailmobile Van Trailer (A63689)
Trailmobile Van...
2003 CASE 70XT SKID STEER (A65053)
2003 CASE 70XT...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
GMC 2500HD 4wd Service Truck (A63689)
GMC 2500HD 4wd...
