Tires Help
   / Help #1
estewart
spartanburg, sc
Hinomoto E2304
My husband is out of the country. We have a hinomoto E2304 series tractor. I need to put air in the tires, but I do not have a manual and the writing on the tires is written in Japenese. Can someone please tell me what tire pressure is recommended for the front and rear tires?
   / Help #2
I am not to fussy with my tires on my kubota. Somewhere between 10 to 15 psi usually works. If I am doing lots of loader work I usually up the front pressure a little. Do you know if your tires are loaded? If they are put the valve stems at the top of the wheel {12 oclock position} before you put the pressure gauge on it. That will keep the fluid inside the tire from getting into the gauge. If you don't know if the tires are loaded put the valve stems at the top anyway.
JMR 72" Root Grapple (A50121)
JMR 72" Root...
2018 HINO 268  NON CDL 26FT BOX TRUCK (A52141)
2018 HINO 268 NON...
2020 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A50323)
2020 Chevrolet...
3 pt Post Hole Digger (A50515)
3 pt Post Hole...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52748)
John Deere 6105E...
2016 Ford F-550 Palfinger PSC3216 Crane Service Truck (A51692)
2016 Ford F-550...
