HELP!
   / HELP! #1
300wtby
Bronze Member
willapa valley
kioti ck25
Well i went out started the tractor picked some logs up that i was cutting shut it off,for about 5 min. went to start it again nothing no glow plug lights no dash lights of any kind the temp guage moved though,
checked the fuses(all good) tried headlights flashers nothing,but the relay was clicking rapidly,then i hit the key again,stopped in acc. position rapid clicking of that relay,out of acc.up one click nothing,so in acc. position rapid clicking of lower relay.any one of these turned on flashers,turn signal, lights in on position rapid clicking of upper relay,located on left hand side of tractor above clutch, anyone with any ideas? the battery is good put volt meter on it.checked every wire connection i could find,totally stumped,......chris
oh,i have a ck-25 hst....thanks
   / HELP! #2
any chance you have a bad ground, have you tried the voltage when trying to start, seen this on a loader that the ground wire was corroded
good luck
   / HELP! #3
how many volts is the Voltmeter reading on the battery (read between the battery + terminal and the frame, do not read from the battery cables) and at the fusebox with the key in the following positions:
1. keyswitch off
2. keyswitch in "on"
3. keyswitch in "Start"
I think your ground cable is not making a good connection. if my guess is correct you will have ~12v at the battery with the key off but it will drop to 8 or 10 (reading from the battery + and the frame) once you turn the key on. however from + to - on the batt will still read ~12v.
HTH
Aaron Z
   / HELP!
ok,ive have 12.5 volts battery to frame the same as post to post,with the key on i have 2.1 volts,been over every wire i can get to dont see any wore through spots, on any of them,removed ground wire from frame cleaned,but wasnt needed, all posts were tight and shiny, cleaned anyway, can one of those relays be bad? its seems that i have one heck of a power draw somewhere......chris
   / HELP!
ok,just looked down a few posts and theres a post by joeld, where he had problems like mine,somewhat different but close,so i went and put the charger on it 50amp boost, well the dash lights came on but when i went to start it it just went dead and the dash lights wouldnt come back on so i let it sit a minute (on ten amps!!) turned the key dash lights come on again but wouldnt start,didnt even make the starter click,so im going to let it charge and try it again later sounds like it might be the battery even though its only 1 year old today. i hope so ......i will let you know what happens and thanx for your quick replys............chris
   / HELP! #6
Hey There,
Based on my recent experience and help from all here.
First, remove battery terminals from the battery, clean the battery terminals real good, clean the leads real good. Put them back on real tight.
Then try. With luck you'll be good and it was just the connections.
Or, if you have a jump pack, remove leads from battery and hook up jump pack. If she starts then it's the battery.
Finally, as instructed. Hook up your volt meter to the BATTERY terminals, check voltage, then turn on light and check voltage.
If you see no drop. Then do same test on leads rather than terminals, if drop it's your connection to the leads.
Mine is all fixed with new battery and everything cleaned and attached tight.
I installed new battery and had same problems, but I had not tightened the positive lead enough, I tightened and she was good as new.
The light went on in my head when I jumped with jump pack and all was well, was getting 14.96 at leads which said charging system was fine, was either my battery or crappy connection.
Good luck,
Feel free to PM if I can help further.
Joel
   / HELP! #7
Boy I have been down this road before...
I know you said you checked the terminals but I would remove each terminal and clean both the posts and the terminals.
Even if they look clean clean them with a wire brush or terminal cleaner same goes for you ground cable on the frame..
When you say you put the charge on it and try to start it and you loose you lights with a click that leads me to beleave you battery terminals need to be cleaned.
   / HELP!
well it looks like the battery just decided it had had enough, put one out of my boat in and it started right up,
joeld,i wish i would have read your post before posting this,but thanks for your input and everyone elses,
wallace,i also thought the same thing,the funny thing is once i took the battery out of the tractor and put the boat battery in it, i went back and put the volt meter back on it again and i got 3 volts,i cant figure it out weather the battery has dead cell"(S) or has broken plates,a short or what dosent make any sense??? my hydrometer got broken a while ago so i cant check,but anyway my dilema is solved,the battery is on the charger and if it dosent take a charge ill go get a repacement 3year warranty......thanks again everyone for your input............chris
i will let you know if it takes a charge or not have never had a battery crap out like this before..................................
   / HELP! #9
Same here, first time I had a battery go from fine to dead in a matter of 15 minutes under no draw. I am wondering if maybe it was my connection rather than battery, I don't think I checked the voltage correctly during all the excitement.
This forum is excellent. These guys saved me a whole lot of pain.
Joel
   / HELP! #10
Are you guys using replacement lead acid batteries or putting in gel cells, AGM, Optima style batteries?
The Optima style battery does cost a bit more but they are made for the harsh environments which our tractors experience and maybe more importantly they will not leak out corrosive acid (or gas) onto your tractor or cable connections.
I can't help but think that these recent battery failures are due to shaking the snot out the batteries.
2016 Ford E-350 Enclosed Service Van (A50323)
2016 Ford E-350...
2017 FREIGHTLINER M2 BOX TRUCK (A51222)
2017 FREIGHTLINER...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
Pallet Fees (A50774)
2008 Ford F-350 Altec Service Truck (A50323)
2008 Ford F-350...
