Help! YANMAR FX20D HYDRAULICS
   / Help! YANMAR FX20D HYDRAULICS #1
mikealvord
Hydraulics working fine 2 weeks ago when i parked it, now ive got nothing no 3 point and fel wont work. No noise from pump no pressure just like the pump quit while it was parked. Weather got down around 30f can this cause this problem. I ve only had this tractor about 2 mo. fluid is full and clean.
   / Help! YANMAR FX20D HYDRAULICS #2
I had a Hinomoto that the key on the pump shaft had broken.
   / Help! YANMAR FX20D HYDRAULICS #3
If there was any moisture in the system, perhaps it froze. Perhaps you have some type of heater (like a torpedo heater) to warm up the tractor. I know in sub-freezing temps my hydraulics take a few minutes to warm up and work. Have you cleaned your screen ?? Not sure about the FX, but the screen on my YM is on the side of the trans. behind a square looking cover. As mentioned, its possible you sheared your key on the pump, but i'd look toward more simple things first.
   / Help! YANMAR FX20D HYDRAULICS #4
In 2 weeks time all the debris in the oil has settled to the bottom of the gear case and it has cloged the filter screen (inside ) the tractor (not) the spin on filter. This has happened to my personal machine
#2
disconnect the return line with a pan under it, start the tractor & see if the pump is gone (sheared)
good luck
Ernies imports
   / Help! YANMAR FX20D HYDRAULICS #5
Having trouble with my FX20D. Rear tire will not engage, only the front tires are engaged. Is there something I need to do? Can anyone help me figure this out, pls....EndresD
   / Help! YANMAR FX20D HYDRAULICS #6
Endres, welcome to the forum. :welcome: You really need to start a new thread for your problem. I don't think anyone can make a diagnosis of your problem with out being there but I can tell you those models are prone to have trouble with the ring and pinion gears. I have seen and worked on an FX24D with a broken tooth on the ring gear and also sheared ring gear holding bolts.
Have you tried engaging the differential lock to see if that affects your rear wheel drive?
Are you from Gainesville, Tx, Florida?
2002 Freightliner FL70 Sweeper Truck (NOT RUNNING)(TITLE) (A50774)
2002 Freightliner...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
1986 John Deere 6359D (A50121)
1986 John Deere...
Cattle Chute (A50121)
Bush Hog 3126R 10' Pull Rotary Mower (A50774)
Bush Hog 3126R 10'...
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
