Help!!!! Yanmar 1601D Injection pump not pumping from one cylinder!
   / Help!!!! Yanmar 1601D Injection pump not pumping from one cylinder! #42
Just loosen a line AT the injectors one at a time while it's running to see which cylinder its skipping on.
Just like pulling a spark plug wire, the dead cyl. wont make a sound difference.. & you can concentrate your efforts ON THAT cyl..
thepumpguysc I have cleaned again and reassembled with the helixes turned opposite of the control rack. Also referred to some screenshots of the manual when putting back together.
Did not realize it the first time that there are timing marks that have to be lined up on the control rack to the control sleeve.
We have had hard rains today so will try to install tomorrow and give you guys an update on how it turns out.
   / Help!!!! Yanmar 1601D Injection pump not pumping from one cylinder! #45
STOP>>>I watched the video.. you f'ed up.. the 2 clamps you removed from the back of the pump are the equal delivery cams..
The ones w/ the pins.. #1 is fixed in a certain position & you move the other 2 to match it, ON THE TEST STAND!!!
IF you hadn't removed them, you would have been F I N E..
MORE THAN LIKELY, your going to shear the pins off when you put the barrels in.. then your f'ed..
Just cut your losses.. send me the pump IN PIECES along w/ the new parts you have & I'll assemble it.. just pay shipping.. about 20.00 each way.
IF you decide to put it together.. the price goes WAY WAY up..
   / Help!!!! Yanmar 1601D Injection pump not pumping from one cylinder! #46
Sounds like the deal of a life time right there !
   / Help!!!! Yanmar 1601D Injection pump not pumping from one cylinder! #47
Listen to the pump guy. These things aren't to be messed with.
   / Help!!!! Yanmar 1601D Injection pump not pumping from one cylinder! #48
I know if i were you that thing would be double boxed and packed with paper and on the way to the pump guy!
   / Help!!!! Yanmar 1601D Injection pump not pumping from one cylinder! #49
I'll send you a PM w/ shipping instructions.. just put the P&B together & everything for each cyl in a seperate bag..
   / Help!!!! Yanmar 1601D Injection pump not pumping from one cylinder! #50
Tick tock, tick tock.eeeeee, the buzzer has sounded.. no email or contact in over 12 hrs.. offer has expired..
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
UNUSED AGT NT18K EXCAVATOR (A51243)
UNUSED AGT NT18K...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2010 KENWORTH T270 SERVICE TRUCK (A51243)
2010 KENWORTH T270...
Bush Hog (A50322)
Bush Hog (A50322)
