Help... Won't Start (New Info)
   / Help... Won't Start (New Info) #11
Re: Help... Won\'t Start (New Info)
I had one that did that and the starter was full of mud. Local starter shop cleaned it for $40.00. Still works great 6 mos later.
Mike
   / Help... Won't Start (New Info) #12
If it isn't the cable connections from the battery to the starter, then my moneys says it is the contact bar in the solenoid. But your best move is to take it off and let the local starter shop clean it up. If the solenoid needs service it is probably brush time too. The starters rarely need bushes or bearings. Starter rebuilds are inexpensive and then it will be good for decades.
   / Help... Won't Start (New Info) #13
"I had one that did that and the starter was full of mud." Yes, mine was packed full of grass and grit. I've never understood how that much stuff could have gotten in there. Jim
<blockquote><font size=1>In reply to:</font><hr>
<hr></blockquote>
The starter is on its way to the shop as we speak. The last think I did was to bypass the solenoid and hook power direct to the starter motor. (Off Tractor) I put negative to the case and positive to the the copper braided wire coming from the motor. El-zippo. Not even a gasp.
Thanks again all for your wonderful suggestions. After the rebuild / solenoid replacement I should be good for another 25 years... ;-)
Dave
   / Help... Won't Start (New Info) #15
<font color=green>Thanks again all for your wonderful suggestions. After the rebuild / solenoid replacement I should be good for another 25 years... ;-)
<font color=black>Very thoughtfull of you to have it fixed correctly, rather than patching it. The next owner will greatly appreciate that!/w3tcompact/icons/smile.gif
These tractor remind me of the old ford 9/2/8N tractors... they live long enough to have multiple 'partners'.
Soundguy
<hr></blockquote>
Next owner??? Its now a family heirloom. My Grandson should still be mowing on this puppy.
Dave
John Deere 60 Tractor (A59814)
John Deere 60...
15200 (A56857)
15200 (A56857)
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
