Help withB7500 HSD routine servicing questions.
   / Help withB7500 HSD routine servicing questions. #1
mfreeland
After paying over $300 for my 1st/last dealer servicing of my B7500 HSD I've decided to do the next one myself but need to know where I can use non-Kubota fluids/lubricants and parts and what I can/should use instead. Here is what I'm looking at changing/replacing:
Engine crankcase oil and filter - 10W-40 oil, ?non-Kubota filter
Transmission case oil - ?alternative to Kubota Super UDT fluid
Transmission oil filter - ?non-Kubota filter
Front axle case oil - ?alternative to Kubota Super UDT fluid
Primary and secondary air cleaner elements - ?alternative to Kubota-brand
Also, how necessary is it to replace the radiator hose/clamp, fuel line, intake air line, and flush cooling system "every 2 years"? My tractor is 3 years old and has just under 300 hrs. Thanks, Mike
159114 (A60429)
159114 (A60429)
2023 SNORKEL A46JRT ROUGH TERRAIN BOOM LIFT (A59823)
2023 SNORKEL...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2018 Dodge Durango Multipurpose Vehicle (MPV), 175,918 Miles, Third-Row Seating (A56438)
2018 Dodge Durango...
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
