Help with yellow diesel cans, please.
   / Help with yellow diesel cans, please. #21
I just keep the mix in by boat tank and use an Ozarks Credit Card (siphon hose) when I need fuel for the chainsaw or weed eater.
   / Help with yellow diesel cans, please. #22
ME...I got a 7000Lb flatbed trailer i haul my tractor on. When I bought it, I went to TSC and bought a 50 gal tank,hose and push/pull pump. Had it welded on the front of the trailer when it was new. Now when I need fuel, its 50 gal fill at a time. When tractor needs filled, just drive up to the trailer and pump a few, hose in the tank, and fill'r'up!. No gas cans, no funnels, no muss, no fuss. AND, i got extra tongue weight on the trailer. It doesnt sit on its jack stand when not in use. Sits on 2 8 x 8 landscape timbers under the frame below the tank. Also when I go do custom work, got all the gas i need along with me.
I just love TBN! Put a request in and before you know it have the information you need! Thanks to everyone, including Harv for those pictures again. More questions coming I'm sure.
Bill
   / Help with yellow diesel cans, please. #24
You can put diesel fuel in a blue "Kerosine" can, it won't mind.
   / Help with yellow diesel cans, please. #26
Bill:
If the filler on the tractor has a screen on it the funnel may provide more fuel than the screen can handle and will overflow.
Check out Harv's fill system. It's simple, cost effective and will probabbly work better than all the others.
Syphons or a small hand operated pump will work too.
As for a yellow can any container that is made for hydro carbons will work and can have some yellow paint sprayed on it.
Your wife will love the smell of diesel impregnated clothing going into the washer.
Egon
   / Help with yellow diesel cans, please. #27
Gary,
I painted both sides OEM Orange..
Carl
   / Help with yellow diesel cans, please. #28
I have one of the caps with the pump... not bad.. just takes a while.
Soundguy
   / Help with yellow diesel cans, please. #29
My flexible spout broke this weekend, so I was back to using the hand pump.. ho-hum...
Soundguy
   / Help with yellow diesel cans, please. #30
HAY WOODY1 any pictures of trailer and tank sounds like a great idea but what size is your trailer lenght does it take away from tractor area I may need a 20 footer now!
Edt
UNUSED WOLVERINE MAD-12-12D HYD AUGER DRIVE & BIT (A57193)
UNUSED WOLVERINE...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
2019 JOHN DEERE 350G LC EXCAVATOR (A52707)
2019 JOHN DEERE...
Hyundai HL 960 Wheel Loader (A56857)
Hyundai HL 960...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
