Help with X585 Error Code
   / Help with X585 Error Code #1
JJE64
X585
After plowing snow and shutting off/restarting the engine, my 2005 X585 shows an error code. The code seems to be "air/fuel calculation error".
Has anyone else seen this issue? Is there a known fix? I have changed the fuel filter and cleaned the air filter.
The tractor never loses power. And once the code appears I can clear it by cycling the tractor on/off.
Any advice/help is appreciated.
JJE64
   / Help with X585 Error Code #2
I had a similar problem the other night after blowing snow for an hour with my 585. I hopped off the seat to open the garage door, and the engine died. I had to push it inside as it wouldn't crank at all. That had never happended before.
I didnt have any error code showing. I figured it must have been snow/mositure under the seat so the auto shut off was malfunctioning. I left it for a day to melt and dry off...and it started with no problem.
Sorry i don't have any advice...other than wait for spring to warm things up!
   / Help with X585 Error Code #3
Make sure all your connections are clean and take off the battery cables and fuses are clean. A loose/bad connection can cause a temporary fault that could trigger that. It's nothing major since it runs good (i.e. sensors, computer, etc). Check the simple stuff.
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55218)
PENDING SELLER...
2022 CATERPILLAR 303.5 CR EXCAVATOR (A52705)
2022 CATERPILLAR...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
