help with vin #
   / help with vin # #1
codeman02
'49 Ford 8N
Hello, so we finally drug out my Grandpa's old Ford 4000, select o shift, diesel. Can anyone help me with some info to find the vin #, we have not had any luck. It runs great, but i need a few things for it, like a front rim etc, any help would be appreciated! here is a few pics
Thanks
Cody
   / help with vin # #2
Tractors do not have VINs, nor titles. That is two reasons thieves steal tractors frequently.
Fill in your location as part of the T-B-N profile. When members know where you are they will help with the wheel rim you need for the Ford 4000. What is the rim size you need? As you know, tractors have multiple tire options, each requires a different rim.
   / help with vin # #3
Serial number will be here under the end of the battery box.
Your tractor is 1963/1965
Kirk
   / help with vin #
Thanks guys ! i will check it out this week
   / help with vin # #5
yep, just aft of the starter on the bellhousing. Note.. on many diesels you will just find a pitted area and no numbers due to battery acid.
still.. won't matter a bit for rims.
most common is a 16" implement rim up front, and ultimately, you just look at the tire and can go by the tire as to which rim you need, if there are 2 different possibilities on width.. etc.
2007 BobCat S175 Skid Steer (A52384)
2007 BobCat S175...
2021 JOHN DEERE 2032R TRACTOR (A51247)
2021 JOHN DEERE...
2025 SDLANCH SDLE18P UNUSED Mini Excavator (A53117)
2025 SDLANCH...
New Holland 650 (A50123)
New Holland 650...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
UNUSED 16" AUGER (A51248)
UNUSED 16" AUGER...
