LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,093
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
If you are going to be leaving your fluid in, I would suggest getting an oil sample analysis to be sure its still up to snuff. usually costs around $30. A visual inspection does not cover all that is of concern. Viscosity and film strength can deteriorate and are very important. As well as any other chemicals that may have been introduced to the system, that will not be filtered out.
My personal preference is to change the oil after the first 50 hours.
I'll second that, also many tractors will have a magnetic plug that needs to be pulled and cleaned as well as a screen on the inlet of the system that should be cleaned either of these will require draining the system. The operators manual will give the minimum fluid specifications and maximum hours and time between filter and fluid changes.
Enjoy it.
