Tire Selection Help with understanding and selecting new tires.
   / Help with understanding and selecting new tires. #21
Running mismatched tires puts a huge load on your differentials and transmission. The rears need to be a matched pair. So do the fronts. In addition to that, the circumference ratio for the front to rear tires must match the tractor's internal 4WD ratio. Maintaining the correct front to rear ratio is why the manufacturer has specified only certain tires for 4wd. 2WD is much more forgiving.....
Looking at your photos, I say you should immediately replace all 4 tires. Running mis-matched tires like that on a 4wd tractor that large in any high traction ground is asking for major repair bills. Your best bet is to use the manufacturer's recommended tire sizes. If you are not going to do that, at least get some advice from someone you trust.
Let me be blunt: The questions you are asking tell me that you don't yet understand how the gearing of a 4WD tractor is affected by the tire size - but it is. You can learn about it, but it will take some study and that will take some time. Until then the best bet is to use the manufacturers recommendation. You've probably got enough other things to do.
Good luck,
rScotty
2008 Chevrolet Impala Sedan (A53424)
2008 Chevrolet...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
2020 Freightliner M2 106 2,000 Gallon Water Truck (A55788)
2020 Freightliner...
2012 JOHN DEERE 329D SKID STEER (A52705)
2012 JOHN DEERE...
UNUSED LANDHONOR BS-12-2500G BALE SPEAR (A54757)
UNUSED LANDHONOR...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A55218)
2019 BOBCAT T630...
