Buying Advice Help with tractor choice
/ Help with tractor choice #1
brianclowry
Turkey City, PA
Ford
Hello, all!
I have an 80 acre farm, ~40 tillable acres. I'm looking to buy a "new-to-me" tractor - one in the 40-55 hp range. I will use it mostly for clearing brush, but I do have a set of 3-bottom Oliver plows and an 8' JD transport disc that I would like to put to use. My land is gently sloped, but I do have quite a few springs that make the ground soggy in areas. I once had an Oliver 880 Row crop gas: too costly to run, no power steering - definitely the wrong tractor for my needs.
Low cost of ownership/reliability are paramount. I have several choices in sight, but I could use help in narrowing the playing field. Or, perhaps there are other machines I should consider (in no order of preference):
1. Ford models 3910, 4610, 4100, 3930, 4600SU
2. JD models 2240, 2155
I really don't have more than $8-9k to spend. Should I spend well below my limit and assume that I will have repairs in the near future, or am I better off spending more in hopes of getting a newer/lower hour tractor?
My neighbor has a David Brown 880 that performs well, but I'm concerned about parts availability with that brand.
Thanks in advance!
Brian
/ Help with tractor choice #2
I bought a Ford 4610 this winter, my first 'big' tractor. I bought it with a loader, my primary use for it. So far I like it. I am looking for some of the implements you have listed, so I am not much help, yet. I don't know much about the other tractors on your list, other than what I have read. They say the SU models have a lighter duty front end, more nimble but not good for a loader.
I have the operator's manual and service manual, too.
If you have any questions about my 4610, let me know.
Arrow Quip MAN-STBR Sternum Bar (A64047)
Arrow Quip...
UNUSED WOLVERINE MAD-12-12D 12" MINI HYD AUGER (A62131)
UNUSED WOLVERINE...
Vegetable Sprayer (A60462)
Vegetable Sprayer...
26120 (A56859)
26120 (A56859)
APPROX (23) 3'X8-10' HEAVY DUTY INSULATED PANELS (A62131)
APPROX (23)...
(INOP) 2019 KUBOTA KX040-4 EXCAVATOR (A62129)
(INOP) 2019 KUBOTA...
