Help with Stihl Farm Boss Idle
   / Help with Stihl Farm Boss Idle #1
logan97
Blue Ridge Mnts, Va
Kubota B7800 4/wd
I have a Stihl Farm Boss and would like to tone the idle down as it spins the chain to fast. I usually hit the brake but it is always not convenient. How do I accomplish this task ?
   / Help with Stihl Farm Boss Idle #4
This is what I find in the 290 Farmboss manual.
   / Help with Stihl Farm Boss Idle #6
Just as a side thought I'd recommend that if it's been some time since the air cleaner has been cleaned that you do so. While you have that apart check the area around the carb and make sure there isn't a build-up of wood chips in there affecting the idle linkage. This all would assume there some time on the saw.
Case Series 2 LGP Crawler Tractor Dozer (A51691)
Case Series 2 LGP...
2025 MAX BUILT 82" X 20' TRAILER (A51247)
2025 MAX BUILT 82"...
JOHN DEERE 8360R LOT NUMBER 146 (A53084)
JOHN DEERE 8360R...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2025 K2030 UNUSED Metal Garage (A53117)
2025 K2030 UNUSED...
