Help with removing a Hydraulic Control Lever
/ Help with removing a Hydraulic Control Lever #1
kubotabx2200989
I have a BX2200 (surprised huh) and the "Rod Feed Back" broke. In order to replace it I need to remove the "Hydraulic Control Lever". It is connected to the pump (I believe it is the pump) by a collar which has two pins in it; #130- a spring pin that attaches the "Hydraulic Control Lever" to the collar and #140 - is a Joint pin that attaches the collar to the pump. I was able to remove the joint pin (#140). It is a tight area to work in and I have tried a number of different methods to dislodge the "Hydraulic Control Lever". I even applied a number of coats of WD-40, but it did not work. I am a hesitant to try really banging away at it. Does anyone have any ideas on how to remove it. Anything would be appreciatted.
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2020 International LT625 Sleeper 48" (A62613)
2020 International...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
New/Unused Landhonor Air Impact Wrench (A61166)
New/Unused...
