Help with PTO RPM calculation
   / Help with PTO RPM calculation #1
coldsteelva
Loudoun County, VA
Massey GC1720 & Mitsu MT180D
I'm new here and have a MT180D with a 3 speed PTO. It's mostly used to haul around a 60-inch Woods finish mower (540 rpm).
1st PTO gear makes 623 RPM @ 2700 (max engine rpm) and 540 rpm is marked off at 2340 engine rpm. So ~86-87%. Second gear (PTO) is rated at 919 rpm @ 2700 (max engine rpm). Can someone confirm, recalculate or pat me on the head and let me know if the following is true? Since it should be linear, if 540 desired rpms is ~58% of 919 max PTO rpms in 2nd PTO gear, then to achieve 540 pto rpms in 2nd PTO gear, I should be able to run at 1566 engine rpms?
Running in a higher drive gear and higher PTO gear at lower rpms should be better all around, no? This assumes that the lower rpms wouldn't stall me out.
Is there any reason why I shouldn't run in the higher gear?
   / Help with PTO RPM calculation #2
I wouldn't use percentage, I would use the RPM, I think it is simpler. So the 1st gear is 2700/623 = ~4.3 so you get about 4.3 engine RPM to 1 rotation of the PTO.
1st gear = 4.3 -> 540 = 2340 engine RPM
2nd gear = 2.93 -> 540 = 1587 engine RPM (so you are really close)
So if you are running in second gear you need to set your engine to 1587 RPM to get 540 at the PTO.
As long as you are not lugging or stalling the motor the higher gear should be fine. It will be a little quieter and save a tiny bit of wear on the tractor. Fuel consumption is going to be almost the same because almost the same amount of work is being done.
   / Help with PTO RPM calculation #3
Most tractors PTO rpm is constant at the rated engine rpm independent of the gear the trans is in. If you are correct, what you have is unusual for any tractor.
Thanks for that. With the analog tach and the throttle lever, anywhere in the ballpark of 1550-1600 is about all I can hope for. Thankfully, I know what 540 sounds like on the mower so I can feather it by ear. On a 30 year old machine, less stress is better in my eyes. On the other hand there are still less than 1300 hours on it so it hasn't had too hard a life. Have a great day.
You have never seen one of these Mitsus then. I have an 8 speed drive gear box R-1-2-3 in Low and High range and I also have a 3 speed PTO gear shift 1-2-N-3
   / Help with PTO RPM calculation #6
He is not talking about travel gears but rather different selections for the PTO itself.
   / Help with PTO RPM calculation #7
Your math should work out correctly.
To get 540 rpm in higher gears you will have to run the engine at rpms which may be hard on the engine. And if you run the mower too fast, that can clearly be hard on the mower and the resultant increase in work and power could kill the engine.
   / Help with PTO RPM calculation #9
My tractor (LS P7010) has a 3 speed PTO gear box, 540,750 &1000. Each PTO speed reaches the rated speed at the same RPM of 1950 engine. I do most times run my bushhog in the 750 gear and just throttle back to maintain the 540 PTO speed. Since 750 is 72% of 540 I reduce the engine speed to 72 % of the 1950 which is 1400. I do increase it to 1500 so the engine is not lugging in heavy material.
I don't agree that the same amount of fuel is used when reducing engine speed when doing the same amount of work. If the engine is running 1950 under almost no load and I reduce it to 1500 still under almost no load, there has to be an improvement in fuel consumption. This would be similar to a car shifting to OD when at cruise speed. The same work is being done but at reduced RPM so fuel is saved. Also there is less wear on the motor at reduced speed.
   / Help with PTO RPM calculation #10
Don't think so
Think again. Lots of tractors have multi-speed PTO gear boxes in them. My Yanmar 4220 had a 4 speed box, my LS has a 3 speed box. I think many tractors made outside of the USA and sold in Europe and other overseas countries have multi-speed PTO gear boxes.
Pemberton 5460 Loader Root Rake (A56857)
Pemberton 5460...
1992 CATERPILLAR 14G MOTORGRADER (A52709)
1992 CATERPILLAR...
Hydraulic spike driver (A56435)
Hydraulic spike...
2019 GENIE S-45 BOOM LIFT (A52709)
2019 GENIE S-45...
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
(INOP) 2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
(INOP) 2015 FORD...
