Rat Rod Mac
- Joined
- Oct 22, 2006
- Messages
- 177
I have a pressure washer that works great when hooked up to the garden hose, but here is my situation. I need to use it where I don't have access to a garden hose water supply. Here is what I thought I may do, but wanted to check here first so if it doesn't work I won't burn up the pump. I was thinking of laying a 55 gallon drum in the back of the pickup truck (which would be above the pressure washer sitting on the ground) and running a short hose to the washer. I have a garden hose fitting welded to a drum bung, but since it's only gravity fed and not under pressure I don't know if this set up will work without damaging the pump. What do you guys think? Will this work? Thanks in advance. RRM
