Help with planter
   / Help with planter #1
Kodiak45
SC
long 2460 - belarus 250 - JD 4230 - Kioti DK40SE
im going to plant my first large garden this year along with some sunflowers for the doves. I recently purchased a 1 row cole planter mounted on a cultivator frame. It was a great deal and i had great expectations on my garden and crops. BUT- My tractor tires are 72" outside to outside & inside width is at 38" give or take an inch. How the heck am i supposed to plant 36" rows or even close to 36" rows with my tractor? moving the tire width is probably out of the question. If i let the tire run 10" away from the last row, then my rows would be 46". How is anything supposed to have decent spacing when planting with a 1 row planter mounted to a cultivator? it seems my best option might be to make a 3pt hitch frame and fabricate a toolbar and then attach the planter to the toolbar so that it can offset one of the tires.. hopefully i am just looking at this the wrong way. what do most people use one row planters for?
   / Help with planter #2
I could have written the above post. I have a Yanmar EX450. Tire width centerline is 56". I bought 2 cole planters mounted on a cultivator frame, set up for 36" rows, along with a spring tooth cultivator, set up the same way. I built a 3 point hiller hiller, and have spent several days trying to figure out how to hill or plant two rows at a time. The experts all tell me that 2rows must be spaced half of the centerline width of the rear tires. That would make my rows on 28" ctrs. I can probably adjust the planter and the cultivator to that width, but that seems awfully close. I have been seriously considering changing over to single row, but the existing wheel spaceing doesn't lend itself to that either. I don't think Yanmar makes any wheel spacers, and having them custom made would probably be very expensive. From what I read, none of the compact tractor wheel widths are set up for standard row crop widths.
Looking forward to someones better ideas.
   / Help with planter #3
Everyone moves the tires in or if you drive about 3 inches from the last row, that would get you pretty close to your target width. Ken Sweet
   / Help with planter #5
Wondering why changing width is out of the question? Is it possible to go to three rows versus one? With 72 inch width a toolbar to go to three rows would work. Might be excessive for a garden though.
   / Help with planter
Then i would need to buy 2 more planters and changing the tire width seems like a huge , which i don't think would solve the whole problem. It seems like 1 row planters on cultivators or ones that aren't on a toolbar are worthless for just one row. 3 inches close to the previous row seems awful close for comfort
   / Help with planter #7
I have changed track width on tractors to plant with and then change back to cultivate with for over 50 yrs. It is no big deal and a part of operating a tractor and using its different variables. 2-3 inches from our corn or tobacco plants no problem at all. The cultivator can be set to take out the tractor tire tracks as you plant. Ken Sweet
   / Help with planter #8
Mgraham, the reason I asked about changing the width is I am in line with Ken's thinking. Changing the width is just part of row crop farming. Most of our row crop/garden work is done with a Massey Ferguson 135 and a Farmall 140 and we leave them set for 36" row spacing. I do use the MX 5100 for tilling.
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
2007 Heil Heavy Duty Aluminum Tank Trailer (A56438)
2007 Heil Heavy...
