Help with noise and surging.
   / Help with noise and surging. #1
MarlinSlayer
Collierville, TN
Ford Jubilee!
Well I got the tractor all put back together except hood. I replaced gas tank, all gaskets, filters, etc. New plugs, adjusted valves, replaced oiler grommet in the valve train, new radiator, hoses, cleaned and fixed up water pump, new thermostat, new radiator shroud (which made me replace a very worn pivot pin, main axel, and gave me a good excuse to remove and replace an axle support bracket bolt), new bushings and spindles and thrust bearings on the front. (I found out the hard way those bushings need to be reamed....good way to meet the nice guys at the local machine shop). I had previously had starter rebuilt, replaced wires, plugs, points, and condenser. Also replaced a worn belt. I just rewired the whole thing.
When I ran it, it sounded great, but with a little sputtering now and then....I had yet to do the carb as I wanted to rewire the tractor with new, but wanted to make sure it ran ok, before I did that. Every once in a while, I'd hear a squeak squeak squeak near the front end. Feared it was water pump or alternator, so I took belt off and ran tractor. Still a squeak. I did notice that when it squeaked was only when there was a stutter. It did not increase with rpm but was "occasional" and it correlated with the surge.
Prayed carb cleaner in the throttle body hoping that would help. with the surge,...I would get puffs of black then it would run clean with an occasional sputter, the squeak still correlated with sputter. I messed with adjustment jets and it seemed to have little effect on engine. This evening after I finished the re-wire, cold engine, the rpm was unstable and wanted to die a bit. I took governor linkage off to see if there was a problem with the governor, and the rpm went all over the place.
I did check my very careful wiring job and checked the spark at the plugs...good...ohms across register and old coil (3.6) just in case my wiring affected something.
Took apart the carb and it was dirty of course and now will order a kit.
My main question is this: if, after the carb rebuild, the engine still surges a little and a squeak is present...is this a governor issue? If it doesn't surge, but squeaks with a change in rpm.....can I put this off for a bit until I tear down next year for paint? I put a screw driver in the place where I figured the front engine bearing would be and sounded pretty smooth...also figured If it was a main engine bearing, I'd hear more noise and it would correlate with rpm...like I said...squeak only happens when the rpm changes and governor shaft is moving.
I've heard you all talk about the balls and race on the governor. I imagine it is a simple fix. Do I need to take the whole front end off to get to governor, (including the axle support bracket, or can I do it with just the radiator removed? What pieces do you have to remove to work on governor, and is there a simple fix for this if the governor bearings and race need to be replaced?
Forgot to add...did the brakes...they were dry as a bone.....looks like someone had replaced axle seals...put on brand new shoes, but failed to adjust them....so I was able to just clean them up....scuff the shoes a little and adjusted them......worked like a champ
   / Help with noise and surging. #3
I would doubt the squeak is a governor issue.
i'd shut down and slip the belt off the genny and restart her with no water pump and genny and see if the squeak was still there...
also.. surging... COULD be governor.. did you mess with the spring any?
does tugging on some choke help the hunting? many times a slightly lean engine will hunt.
also.. if hunting.. does it only hunt at idle.. or will it do a near stall and over-rev at load ?
post back
post back
I did pull the belt......sounds like it is coming from the front of engine....not the water pump or alternator. I ripped apart the carb so I'll let you know after I rebuild it. I didn't mess with the spring. (did you mean the tension spring or the linkage that goes to butterfly?)
   / Help with noise and surging. #5
Tension.
So with no belt it squeals?
not a squeal...more like a combo chirp squeak when rpm surges....no chirp squeak when rpm are stable
   / Help with noise and surging. #7
take a can of spray oil.. wd40 even.. or something like penetrant.. pb blaster. spray the crank pully aft at the timing cover... see if it makes a difference.
( no belt on of course... thus no water pump or charge device )
   / Help with noise and surging. #8
sounds like a head gasket leak for my money
   / Help with noise and surging. #9
where are you seeing head gasket leak?
head gasket I think is fine. No water in oil, no oil in water....good compression on all 4
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
2017 Ford Expedition 4x4 EL XLT SUV (A51694)
2017 Ford...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A53473)
2012 NEW HOLLAND...
