help with lift on 640
   / help with lift on 640 #1
spd132
I have a 1955 Ford 640. When you start it after it has been setting overnight, the lift will not work at first. You have to lower lift lever all the way and then raise a couple of times and then it will work the rest of the day. Does anyone know what would be causing this? Haven't had the tractor but about 2 weeks so haven't had time to really dig into it to find problem.
   / help with lift on 640 #2
1st, check the oil in the hyd sump... see if it is milky ( water )
2, check the oil after using it a bit... is it foamy? ( oil and maybee water )
3, if you remove ( loosen actually ) the inverted plug in the head o f the pump at startup till oil trickles out, then tighten plug, will the lift work immediately?
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
2015 Case 580N EP Loader Backhoe (A53117)
2015 Case 580N EP...
2021 QUALITY CARGO, LLC QUALITY CARGO, LLC (A53843)
2021 QUALITY...
ROLL OFF BOX (A53843)
