Help with Ken's Bolt on Hook
/ Help with Ken's Bolt on Hook #1
dchemphill1
I am drilling holes for my Ken's bolt on hooks in my 525 loader with quick attach bucket and have run into an issue. As the drill bit got almost through it gets hung up because the underside of the bucket has two plates and they are not even so the bit has gone through part of the top of the bucket but the rest I can not remove because the drill bit catches.... Can I try to punch it out.....should I get a torch and try and heat it....stuck and not sure what to do. Ideas?
This will be an issue all along the top of the loader bucket. I did not want to mount it with part of the hook base hanging off the edge..figured that would weaken the whole hook assembly.
Thanks All
/ Help with Ken's Bolt on Hook #2
Do you have a Dremel tool? If so you can use a small grinding stone to remove that extra material of the second layer, a round file should work also. No torch should be needed.
This is what you have correct?
/ Help with Ken's Bolt on Hook #3
Unsolicited customer service from the vender in 28 minutes. Remarkable.
Thanks a bunch the dremel tool worked. I will say this the drill bit dulls quickly.
/ Help with Ken's Bolt on Hook #5
Great DC! :thumbsup:
/ Help with Ken's Bolt on Hook #6
You can also spin the bit in reverse with some pressure to remove that small chip that is hanging up the drill bit.
Done! Pictures attached
/ Help with Ken's Bolt on Hook #8
Very good DC, thanks for the pics!
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
2012 Caterpillar 302.5C Mini Excavator (A61572)
2012 Caterpillar...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2024 Freightliner M2 106 Altec DM47B-TR Insulated Digger Derrick Truck (A61573)
2024 Freightliner...
CASE INTERNATIONAL 230 - 35' TURBO TILL (A63291)
CASE INTERNATIONAL...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
