HELP WITH HOOKING UP BRUSHOG UPDATE
   / HELP WITH HOOKING UP BRUSHOG UPDATE
Hi,
I don't have a rotary cutter yet, so I am still learning too.
But, what might happen if the front edge of the cutter hung up on a small stump or rock? The pivot point would be the front edge I think.
The tractor pulling could possibly cause the the rotary cutter to pivot about the front edge, the rear coming up and flipping towards the rear of the tractor. A chain would not hold it back. A rigid top link might...
Now I would guess the PTO shaft itself might also hold the thing back...so perhaps having a chain or normal top link, in the practical world, makes little difference...
Thanks to all those with experience for their continuing advice. Truly helpful to us learners!!!
Bill in Pgh, PA
Bye the way, it doesn't take speed to make bad things happen, but power.
The low gearing of tractors makes them amazingly powerful, as you know.
Backflips at near zero speed, sometimes with fatal results, are a real possibility with a tractor...no one should equate speed with danger when it comes to tractor use...I would say this is the same for something we are pulling behind us. If the worst case happens...well... let's hope it doesn't!
Better safe than sorry...
Bill in Pgh, PA
   / HELP WITH HOOKING UP BRUSHOG UPDATE #13
http://www.ytmag.com/articles/artint57.htm I see you did not read this thread from the first post you made on this subject. If you had you should read all of it. It will tell, you just what I said. Some people even on here, think they know all the answers, but no one ever does. And when it comes to saving ones life or limbs, they should read and do all they can do. But of course you can do what you like, I won't take the chance, it's not worth it. The article goes on to say, the rotory cutter is the most dangerous thing you can operate with your tractor.
   / HELP WITH HOOKING UP BRUSHOG UPDATE #14
A few years ago I was watching a man brush hog a hill side with some pretty heavy growth. He had borrowed the tractor from his buddy (bad idea). I don't think he was paying any attention to the mower and both lower link pins sheared off, the front dug in and the mower stood straight up before he could stop the tractor. No one was hurt, thank God, so it can happen. Now I don't know if the top link saved him or not.
Some of the Bushhog models I believe use the chain instead of the top link. Always be safe if you don't think it can happen it will.
I hook mine up with the front off the ground about 2", using the position control and loosen the top link until the swivel is loose basicly the way you did it but with the top link installed.
Solo
THANKYOU FOR MAKING ME WORRY A LITTLE MORE ABOUT THIS.I THINK I'LL SEE IF I CAN'T MAKE A SHORT CHAIN CONNECTION TO GO ON THE TOP OF THE CUTTER AND THAN HOOK UP THE TOP LINK TO THAT SOME WAY OR THE OTHER. RICHARD .AND YOU ARE RIGHT ABOUT THE MANY OPPINIONS,BUT THATS HOW YOU LEARN THINGS.I THINK FROM THIS WEB PAGE AND OTHERS LIKE IT,I HAVE GOTTEN EVERY POSSIBLE WAY YOU CAN HOOK UP A CUTTER AND I'LL JUST HAVE TO FIGURE OUT WHICH COMBINATION WORKS BEST FOR MY SITUATION.I CAN TELL YOU DON'T WANT TO ADJUST THE HEIGHT THE WAY THE KINGKUTTER MANUAL SAID AND PUT THE CONTROL LEVER ONFLOAT.ALSO ICAN TELL YOU THAT IF YOU ADJUST THE FRONT HEIGHT BY LENTHENING THE TOP LINK YOU ARE PUTTING A LOT OF STRESS ON THE CONNECTIONS AND I BELEIVE IT WOULD JUST BE A MATTER OF TIME BEFORE SOMETHING BROKE. NOW THE TOP FLEX SWIVEL THING IS SOMETHING I DON'T HAVE AND DID NOT COME WITH THIS MOWER WHICH IS PAINTED BLUE, BUT I'VE HEARD THI DON'T WORK TO GOOD ON THE KINGKUTTERS ANYWAYS.THE ONLY WAY SO FAR THAT HAS WORKED FOR ME IS NO TOP LINK OR ACHAIN FOR A TOP LINK SO YOU CAN PICK IT UP.NOW LIKE I HAVE SAID BY USING A SHORT CHAIN ON MOWER TOP CONNECTOR AND THAN CONNECTING THE SHORTEND TOP LINK TO THAT SEEM LIKE IT WOULD BE MORE SAFER,BUT IN ANY CASE THANKS TO TRAIL AND ERROR AND TO WHAT I'VE READ OFF THE COMPUTER,I'M NOW ON THE RIGHT TRACK. THANKS AGAIN,RICHARD
   / HELP WITH HOOKING UP BRUSHOG UPDATE #16
I am not an advocate of putting a chain in place of the top link, but it seems to me this still would be safer, since the bottom links are still there, than all those "trailer" type brush hogs. I've never heard anyone comment that they're unsafe, and yet the exact same thing could happen. In fact, the trailer type could also swing sideways, but again, I've never heard this happen either. Seems were making too much of this. My guess is, just like with a top link on, when you hit something, the cutter lifts up slightly, and then something else happens, either the tractor stalls or the deck lifts over the obstruction or something breaks.
   / HELP WITH HOOKING UP BRUSHOG UPDATE #17
Instead of a short pc of chain get 2
1/4 x 2" x 8" straps and drill 3/4" holes
near each end .
Put these as a link between top link
and mower top link so they the tail of
mower can float.
Someone showed u a picture of this set-up
on your other post.
These plates solve both of the problems.
2015 Peterbilt 348 Jerr-Dan T/A Rollback Truck (A55852)
2015 Peterbilt 348...
2018 John Deere 5075E MFWD Tractor (A53485)
2018 John Deere...
24" EXCAVATOR BUCKET (A52707)
24" EXCAVATOR...
2005 Ford F-250 Service Truck (A55852)
2005 Ford F-250...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
