Help with hesston 1320 modular cutterbar
   / Help with hesston 1320 modular cutterbar #1
rrch129
Hey guys been on ytmag.com for a long time and hardly visit this site just because it seems like you guys run some smaller operations or farm more as a hobby but i like the site. Anyways i cant get an answer over there. Got a 9 foot hesston 1320 discbine recently (have yet to pick it up) and there is one bearing in the cutterbar out. How difficult will this be to replace and how should i go through and check for other bad bearings? Have had two mower conditioners, haybines whatever you wanna call um but this is my first discmower.
   / Help with hesston 1320 modular cutterbar #2
Assuming the bad bearing is on one of the disc units, you should be able to unbolt it and pull the unit from the top I think. Then change the bearing on the workbench. If it's on an idler I would say you would still have to pull a drive unit to get to it. Some cutter bars you have to slide all the idler and drive assemblies out the end, so you get to inspect them all anyway. I have'nt worked on many Hesston mowers but all the other ones I've done have been similar to this procedure.
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
2013 PETERBILT 388 T/A DUMP TRUCK (A51247)
2013 PETERBILT 388...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2018 FREIGHTLINER...
2015 Caterpillar 410L 4x4 Extendahoe Backhoe Loader (A51691)
2015 Caterpillar...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
2020 Bell B30E Off Road Dump Truck (A53117)
2020 Bell B30E Off...
