Help with fuel consumption of 6 HP engine.
   / Help with fuel consumption of 6 HP engine. #1
chad22
Kansas
Sears Garden Tractor
I'm looking at 6 HP engines to power the hydraulic pump on my home made excavator.
Looking to replace the 18HP as I think the 18 HP is overkill for powering my 2 GPM hydraulic pump and the 18HP engine burns through gasoline way too fast.
I'm thinking of the engine at this link. New 6 5HP Gas Engine Go Kart Log Splitter Mini Bike Stream Easy Start Motor | eBay
I need help with figuring out the fuel consumption
I see it says.
(Fuel consumption: 395g/kw.h)
So how much fuel would this engine burn in an hour?
Thanks
Chad
   / Help with fuel consumption of 6 HP engine. #2
Hi! Honda engine burns 330 gr Hp Hour. 6 Hp about 2 liters hour or half us gal. Good luck Oldmech
   / Help with fuel consumption of 6 HP engine. #3
A lot of people like these chinese engines. Often they pitch them and buy new if anything is ever wrong.
Thanks for the help figuring this out. I really appreciate it. :)
Chad
   / Help with fuel consumption of 6 HP engine. #5
A little planning ahead would have saved time and money. A 2gpm pump at 2500psi would require approx 3.5HP .
The gas guzzler Opposed Twin Briggs and Stratton that's on there right now was one I had just lying around. It's a great running engine but it's just too much power for my little excavator and it's pump.
Once I order the new engine I'm gonna use the Briggs on an old sears riding mower I'm gonna restore eventually.
Chad
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
