Help with finding Rotary Cutter Blade Bolt/Nut or Alternative
   / Help with finding Rotary Cutter Blade Bolt/Nut or Alternative #1
jclaudii
River Valley and South Arkansas
MF35, Kubota7040, Case885, Ford 1100
I have an old Servis Sat6 bushog and when I pulled the blades and carrier off for inspection and sharpening earlier this year I noticed I need at least one new nut for the blade bolt as it has mushroomed. Servis is now owned by Rhino AG and as I was able to find some factory options. Funny thing is, I would think I would be able to locate a nut fairly easily but perhaps I'm not searching in the right places.
Here are the blade bolt facts:
3/4 inch bolt, LH thread 16 tpi, 3 inches long, one inch blade hole "flange"
Here is a Kit I found, but I'm not sure about the company yet. This may be the way I go as 11 bucks for new bolts AND lock nuts is a great deal. Their shipping option is about 14 bucks though for two bolts LOL!
BLADE BOLT KIT-SERVICE/RHINO | Rotary Cutter Supply
a d
Part #'s:
Kit: B36107A2ALH
BOLT# 125-908
NUT# 5GL12160
Nut Other - A-7A5512
All attempts to find the kit locally have failed or even find it for a decent price. Any help would be greatly appreciated. I went to my local fastener (not fastenal) store and they sold me a nut that fit the bolt, but the markings on the nut a "i" lead me to believe it is Grade 1. It is also not a Locknut either.
Thanks for the Nut Help. I'll get some pics to show the damage to the nut.
   / Help with finding Rotary Cutter Blade Bolt/Nut or Alternative #2
Your nut is likely a grade 5, or "standard", bit of hardware.
Here is the nut that was sold to me by my Local Bolt/Nut shop.
Here you can see the Rusty Nut that has the mushroomed end. It appears to be a locking nut with two triangle looking indention's on opposite sides. The new nuts screw all the way on very easily and without a lock washer they may vibrate loose over time. Even with Locktite on this particular application I would be worried.
   / Help with finding Rotary Cutter Blade Bolt/Nut or Alternative #6
With properly applied Loctite I wouldn't worry. Heck, use red Loctite if you are worried—but you may need to heat it to remove it!
Just bumping this up for those who have more fastener knowledge than I. I returned the nuts I got at my local bolt/nut store. I'm hoping someone knows of another brand nut that would work like a woods, bushhog, etc.
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2008 CATERPILLAR 430E BACKHOE (A51242)
2008 CATERPILLAR...
PAIR OF 29 FT PIPE RACKS (A50854)
PAIR OF 29 FT PIPE...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
2011 MAMMOTH UTILITY (A50854)
2011 MAMMOTH...
