Help with cross reference for Jinma 284
   / Help with cross reference for Jinma 284 #1
markh1
Story City, IA
2003 Jinma 284LE Y385T
I made a new post because I thought maybe people thought I was listing cross references but I have a problem.
I found these cross reference numbers on a couple of different sites.
Oil Filter - NAPA 1516
Fuel Filter - NAPA 3195
Air Filter - NAPA 2276
I was changing oil and the filter doesn't fit. I went to NAPA website and it says Oil Filter Thread Size (inches) : 3/4 - 16. Any help would be appreciated.
Mark H
   / Help with cross reference for Jinma 284 #2
Mark
I use a PH3950 from Fram. Here is a cross to the Napa 1381. It has a metric thread of 20x1.50
Oil Filter (Gold)
Chris
   / Help with cross reference for Jinma 284 #3
Here are the filters I use on my 2003 tractor.
Air= Purulator A42019
Oil= Fram PH3950
Fuel= Fram P6503
Chris
Chris,
Thanks for the info. Went to NAPA and got the 1381 oil filter.
Mark H
   / Help with cross reference for Jinma 284 #5
So did the 1381 work? Dont leave us all in suspense.
Chris
Chris,
I am at work and won't know until tomorrow.
Mark H
Chris,
Yes the NAPA filter fit. Thanks for the info.
Mark H
   / Help with cross reference for Jinma 284 #8
Dual post here.
The other numbers I listed for the fuel and air will work for you also.
Chris
   / Help with cross reference for Jinma 284 #9
Hi guys,
I used that Napa 1381 oil filter for on Loretta's 284.
I found a Baldwin (B202) cross over with 20 x 1.5mm threads. It's a little larger in diameter and a lot taller. It fits perfectly on her Jinma and has a lot more filtration surface I believe.
Click here for the specs on it: Baldwin B202 Oil Filter Specs
But I didn't buy it from that link.
I found a much better price on this link: Icon Heavy Duty Baldwin B202 Filters
I bought a case of 12 filters for $5.74 each.
I also buy oil filters for my Kama 554 from them.
I had a conversion oil filter installed on my Kama that took a Baldwin B243 filter with 3/4-16 thread. I found a larger Baldwin filter (B2) about the same size as that B202 with the same 3/4-16 thread and bought a case for $3.51 each. The larger filters might be desirable, especially at those prices.
For comparison, I took these photos when I got the B2 filters to replace the B243 I was using on the Kama. I didn't take any of the B202's yet, but you can get an idea from these photos. The sealing gasket is the same size and the filtration material is the same ... just a much larger filter.
Rob-
   / Help with cross reference for Jinma 284 #10
I came here looking for help for the oil filter for my 2006 Jinma 284 when I drained my oil and the Purolator crossover wouldn't tighten. Most did not work including the NAPA that I ordered next and several others that I now have stacked up in my garage. I had a WIX filter last that worked well and when I put it back on it blew off when I started the tractor.:mad: In a panic I got the oil filter from my wife's 2005 Prius and it fit perfectly. It was too tiny so I ordered several others which again didn't fit. :eek: I tried both the 3/4 and metric sizes and none worked. I even ordered those that were domed upward inside the filter and they wouldn't tighten.:confused: What I noticed is the short length on the threaded nipple where the filter screws on and the threads were not engaging far enough. The Prius filter had a domed upward area in the filter, but it also had an upward facing threaded area where all the other filters the threads went inward. I just so happened to be changing oil in my 97 Jeep Wrangler and saw that filter had both too and was a bigger filter. I tried it and it fit perfectly. It is readily available at Wal-Mart too. It's the FRAM PH16. It's not a tall filter and is the same length as the factory filter, but it works and I'm happy.:D
PALLET OF BRAKE AND AXLE PARTS (A50854)
PALLET OF BRAKE...
2013 Jeep Grand Cherokee SUV (A48082)
2013 Jeep Grand...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A51039)
2023 New Holland...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
PICKUP TIRE CHAINS (A50854)
PICKUP TIRE CHAINS...
2017 Crane Carrier Co LET2 Side Loader Garbage Truck (A48081)
2017 Crane Carrier...
