Help with CK20 noise
   / Help with CK20 noise #1
sschriber
Bronze Member
Southern Adirondacks
Honda 5013
When my CK20 is cold and just started I've noticed a somewhat loud, intermitant noise of a medium pitch coming from the bottom of the engine when in neutral and the clutch pedal is out. Not a grinding sound. It may be part of the gear train, but it is intermittant. 2 secs on then 1 off, 3 on 1 off, etc. The tractor has a little over 40 hrs on it. Have others CK20 shift owners heard similar sound?
Also, I've notice the previously metioned "unwind sound" when the loader actually pushes the tractor back while engaged in forward gear. Is this harmful to the transmission?
   / Help with CK20 noise #2
I have a CK20 gear with about 300 hours on it. I don't notice the noise when starting cold, might be there and just haven't noticed. I do get the 'unwind sound' you refer to when working it hard and no problem yet.
John Deere Quick Attach Pallet Forks (A50514)
John Deere Quick...
2005 Cat DP40KL Forklift (RUNS) (A50774)
2005 Cat DP40KL...
CFG Industrial MX12RX (A50121)
CFG Industrial...
40' CONTAINER (A51244)
2003 VIKING  CEMENT MIXING TRAILER (A52472)
2003 VIKING...
Cattle Chute (A50515)
