LividTaco
Got a 2015 BX25D that started sucking air intermittently couple months ago. Strange to me it's not all the time (at least that I've noticed) and that it doesn't always, until recently, cause power loss in backhoe or FEL.
-FEL quick connects appear fine
-Backhoe quick connects appear fine though sounds like possible air movement in return/recirculating line so got male/female on order just in case.
-No visible leaks on all hydraulic lines
-Trans/hydraulic oil changed 2 weeks ago and again this past weekend due to oil becoming black within a week
-PTO Control dial was very hard to operate due to shafts being bent, upon removal found oring cut in 2. (Think I cut it in 2 on accident removing it but good possibility it wasn't seated correctly causing removal to cut it between threads
-Disassembled tractor all the way down to pump, no oil spots or anything from small leak
-Noticed foaming in oil month or so ago, but as stated it seems intermittent.
-transmition casing gasket peeling off from outside in many places. (Hard to tell if actual seal inside/out is/has been broken. Going to apply additional layer around casing just in case)
-Removed both FEL and backhoe attachments amd then ran tractor and hydraulic fluid still foaming. So definitely tractor side (I would assume)
Has anyone ekse had this or similar issue? If so what was fix? If not any suggestions or anything else i should check. Believe the PTO CONTROL dial o-ring to be the culprit which would explain the intermittent, as I don't use any mid attachments and I had recently used dial to get under armor on/off for filter replacement.
Also by chance anyone have pictures of hydraulic line flow/functions��?
Thanks!
Thanks!
