Help with a Snow Plow for my Cub Cadet 2164
   / Help with a Snow Plow for my Cub Cadet 2164 #1
mayfield19
I have a fairly new ATV Plow and would like to use it on my Lawn Tractor. Is there any ideas on how I could mount it?
   / Help with a Snow Plow for my Cub Cadet 2164 #2
Welcome to TBN.
Most ATV plows use an electric winch for raising the plow and gravity for lowering. Is this how yours works? You might send us some pics of the plow and the recipient and than maybe your will get more concrete suggestions.;)
Mike
   / Help with a Snow Plow for my Cub Cadet 2164 #3
I just did this on my Kioti. I have a swisher brand 60" plow. I had to fab up a way to mount it to the FEL on the tractor. 4 bolts and 1 pin it's on and off in just a few minutes. It can be done you just have to get creative! Mitch
   / Help with a Snow Plow for my Cub Cadet 2164 #4
Pictures are worth a thousand words gentlemen ..... I would like to see both the problems as well as others solutions!
   / Help with a Snow Plow for my Cub Cadet 2164 #5
I fear that the frame of the Cub Cadet 2160 may not be suitable for a plow?
Perhaps for a few inches of snow , but, watch out for hitting rigid objects, it could damage your frame.
Did Cub ever offer any kind of plow with this riding mower?
   / Help with a Snow Plow for my Cub Cadet 2164 #6
Here are a couple of photos of my '73 Wheelhorse with front plow. These aren't the greatest of pictures but they might give you some ideas.
The plow has it's own subframe that slides under the front wheels and goes all the way back to the rear axles where they are attached with a quick disconnect mechanism. The plow is raised and lowered using the same mechanism that raises the mower deck. This one is kind of cool because it has a lever on one side that allows you to angle the blade left/right or center detente. At it's highest point the bottom of the plow is about 10" off the ground. Chains are a must on a machine of this size.
Cheers, Erik
1991 International 4900 Box Truck (A55315)
1991 International...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
PALLET OF 2" X 4" STEEL TUBING & SITE PANELS (A54757)
PALLET OF 2" X 4"...
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
2018 John Deere 8320RT Track Tractor (A53485)
2018 John Deere...
