Help...wires on my 425 ripped by a stick
   / Help...wires on my 425 ripped by a stick #11
J_J said:
Are the oil temp senders pretty standard?
Usually you buy the temperature sensor with the gauge, so there is no calibration requirement.
Most transducers are fairly standard (0-10V or 4-20 mA), but the sensors have varying temperature or pressure ranges corresponding to the 0-10 V (or 4-20 mA) scale.
I did not draw the schematic above, it came out of the Robin EH65 22 Hp engine service manual. Bobrip pointed me in that direction when I was trying to figure out how to hook up the low pressure alarm.
The real trick with the temperature gauges is figuring out where to install the engine oil sensor. I threaded one into one of the drain holes on the block, but couldn't get it to seal (the hole has straight threads, and I could not find an adaptor which would fit my pressure transducer). I ended up using an oil filter relocation kit, but don't really like that solution either.
I used a hose clamp to clamp one onto the inlet hose to the hydraulic cooler. I have never seen this get more then 130F, so I don't believe this is the best indication of hydraulic temperature, since I believe much of the hydraulics bypasses the cooler. I think the best solution is to drill and tap a hole to insert it into the hydraulic tank or attach a thermowell to the hydraulic tank cover (which Clarke did):
http://www.tractorbynet.com/forums/power-trac/88385-mini-modification-4.html#post1006075
Well...I re-wired the PT. From my engine manual, the two wires left unwired are a gray wire from the oil pressure switch and a black wire that the manual shows going to tacho/hour meter. Everything seems to be running fine...the fan kicked on after 15 or 20 minutes of use.
I just noticed this, but I'm assuming the body of the PT has always gotten very hot and I just didn't notice before. It stands to reason that if the hydro oil gets hot, that heat will transfer to the metal frame of the PT...I was just surprised how hot the frame gets. Is this normal? Should I be concerned about something?
   / Help...wires on my 425 ripped by a stick #13
The hydraulic tank is part of the frame of the tractor. After an hour or two of heavy use, like mowing, the tank will get too hot to touch. This is normal. The best thing you can do is keep the oil cooler clean and make sure the fan is working.
   / Help...wires on my 425 ripped by a stick #14
My 422 gets pretty warm too, especially when mowing. I usually use my pt for mowing or the bucket for digging type work. The digging, even in hard clay, doesn't put near the amount of heat into the oil as mowing does.
   / Help...wires on my 425 ripped by a stick #15
I think the radiated heat from the exhaust manifold and muffler add significantly to this temperature.
I believe that PT's use of 1" square tubing with 90 degree corners significantly chokes the exhaust, raising engine temperature. The uninsulated exhaust header across the middle of the engine compartment doesn't help either.
One of the things on my project list is to weld up a new exhaust manifold with round tubing and smooth corners, possibly even dual mufflers like Beechwood and Rivco did with their PT180s (Unfortunately the pictures disappeared, they both did a great job with the conversion... sure wished I had saved the pictures):
http://www.tractorbynet.com/forums/power-trac/87286-180-mods-2.html#post991267
http://www.tractorbynet.com/forums/...ler-4.html?highlight=dual+muffler#post1172262
   / Help...wires on my 425 ripped by a stick #16
Tim,
Good luck in the conversion! Why not go the whole 9 yards and have the headers and muffler coated with a ceramic insulating coating to keep the temperature down in the engine compartment?
All the best,
Peter
   / Help...wires on my 425 ripped by a stick #17
I hadn't heard of that before. Is it commonly offerred by local companies?
I tried wrapping my exhaust header with fiberglass insulating tape, which I think is only a stop-gap solution (smoothy exhaust flow would be better), since I suspect that this just means that it conducts more heat right up to the cylinder head.
   / Help...wires on my 425 ripped by a stick #18
Powedercoating is a wierd process where the metal object is charged electrically, then some sort of electromastic paint is sprayed on. You then bake the part in a hot oven for a while and you have this tough as nails covering over your metal object in really cool colors.
On muscle cars, we powdercoat the exhaust headers so heat is reduced in the engine compartment.
Yes, it works well and it is available in your area I am sure. Heck, you can buy a kit do do it if you want.
   / Help...wires on my 425 ripped by a stick #19
I am familiar with powdercoating. We do alot of that for protection of pieces and parts onboard USN submarines (just finished 4 year stint building the USS HAWAII at Electric Boat Shipyard).
I just didn't realize that people applied this process to their exhaust manifolds. If I ever get past the planning stage on this exhaust header thing, I will look into it.
The process is temporarily on hold because my PT422 is in a storage unit and I am living in an apartment... really expected this to be only a 1-2 month deal while I sold my old house, relocated, and bought a new house.
The housing market is a pretty chancy thing right now, so I am sitting tight while I watch the explosion of number of houses for sale. The funny thing is that despite the incredible number of houses for sale, I haven't really seen much change in the asking price for the past 7 months. I suspect that alot of people are upside down on their mortgage, and can't afford to lower the price, whether because they purchased recently or that they saw the rapidly increasing housing prices a copuple years ago and cashed in on a significant equity loan to "upgrade" their house.
It is quite amazing to see some pretty nasty looking houses that people have obviously spent $50k on adding hot tubs, upgrading the kitchen, etc. Sort of like gilding the pig. I am a bit leary of buying a house that the owner purchased new for $155k five years ago, and now thinks is worth $400k. I really don't want the hot tub or the stainless steel appliances and granite countertops.
   / Help...wires on my 425 ripped by a stick #20
Just FYI on Powdercoating. There is a belief in the auto world that the you should use silver or white on your powdercoating to help reflect the heat. Someone out there has to know if this is bunk or not. I think a nice bright yellow or red would be a good color on your 425.
As for the housing market. Our house in LA has gone down in value for sure. My parents are shopping in Eugene, Oregon, and they are having the same experience you are.
I am hearing good things about finding short sales, but it takes some looking to weed through the chaff.
I think you are right to wait this one out. At least until we have a new president. But it sucks to be you. An apartment when you could afford a house is no emotional fun.
Carl
UNUSED JCT 84" HYD DOZER BLADE (A57193)
UNUSED JCT 84" HYD...
2018 ASV RT30 Forestry Posi-Track Compact Track Loader Skid Steer (A55851)
2018 ASV RT30...
JOHN DEERE 6000 SERIES BRUSHGUARD (A57192)
JOHN DEERE 6000...
UNUSED FUTURE CW59 59" HYD COMPACTION WHEEL (A57193)
UNUSED FUTURE CW59...
UNUSED 1RANCH 1RIF 111.02" X 64.96" WROUGHT IRON (A57193)
UNUSED 1RANCH 1RIF...
Pallet of 3' LED Lights (A56469)
Pallet of 3' LED...
