Help-what is stopping distance on gravel roads
   / Help-what is stopping distance on gravel roads #1
mdbarb
Northern California
B21
I can't find the answer so I'm turning to my TBN team.
I have been searching the net to find facts on what the stoppping distance would be for a vehicle traveling various speeds on a gravel road.
Can anyone point me to a page with such info?
Thanks in advance
   / Help-what is stopping distance on gravel roads #2
Re: stopping distance on gravel roads
First, I don't have a page with such info, but I grew up (i.e. I put in some time) driving on gravel roads in Iowa. It will depend on many factors and conditions of the gravel, the kind of gravel, when it was last graded, and what the recent rains (weather) and traffic conditions have been. Sometimes gravel roads would have a solid base, and be near to concrete. Other times there would be loose gravel and be like driving on marbles. I couldn't possibly think that all these conditions could be controlled well enough to come up with a "table" of stopping distances at various speeds, let alone trying to describe the vehicle (weight, tires, speed, etc.) that would also have to be controlled. I will be interested in what is available from the TBN folk.
I have been able to find charts showing stoppping distance at different speeds on an ashpalt or concrete surface but gravel would be quite different. I just need a legitimate reference - I'm sure the studies have been done and even more sure the TBN crew knows about it
   / Help-what is stopping distance on gravel roads #4
What might you be using this information for? Sounds interesting.
   / Help-what is stopping distance on gravel roads #5
Speed equals 5.5 times the square root of the distance of the skid (all wheels locked) times the coefficient of friction for the road surface plus or minus any grade.
S=5.5 * Square Root of (D*(F±f)) (Sorry about this formula, I typed it in Word and copied it and lost the radical sign that is the the righ of the 5.5.)
Therefore, (stopping) distance equals the speed squared divided by 30 times the coefficient of friction for the road surface plus or minus any grade.
D=S^/(30*(F±f))
The coefficient of friction for gravel is between .40 and .55, slightly better than snow. All this depends on all wheels locking for an all wheel skid. Braking, non-locked wheels will have a shorter stopping distance. The smaller the number on the coefficient the slicker the surface and the longer the stopping distance.
   / Help-what is stopping distance on gravel roads #6
Turfman -
<font color=blue>The coefficient of friction for gravel is between .40 and .55, slightly better than snow</font color=blue>
I'm no mathematician, but with a little speed on a gravel road, I have to concur - it can get pretty "slick"!
   / Help-what is stopping distance on gravel roads #7
Usually, about 2 feet more than the distance to the back of the stopped tractor towing 3 full grain wagons.
Seriously, the answer ought to be in here someplace;
www.catair.net/carsearch.asp?stage=1
   / Help-what is stopping distance on gravel roads #8
Don't think so!!
Infinite variables in infinite combinations make for infinite solutions.
Love driving a rear wheel drive on a well graded, smooth, windy gravel road and steering with the accelerator
Franz; you have put forth the best answer yet.
Egon
   / Help-what is stopping distance on gravel roads #9
Depends on the gravel. On most of the major highways that cross the mountians out west there are gravel traps to catch run away trucks (the ones that have lost their breaks). The traps deap gravel pits with some very solid tie downs for the tow trucks to use when removing a truck from the trap. The breaking distance is less than 50 feet.
carl
   / Help-what is stopping distance on gravel roads #10
The one's I've seen in the mountains in Canada, Carl ... may be gravel or may be sand ... and depend as much on grade as they do depth of the "fill".
But you're right, the drag from the fill stops the trucks pretty quickly in those "brakeaway lanes".
"braking distance on gravel" - if you have to ask, prepare for impact!
pete (who spent much of his life living on gravel roads and was once accused of being totally insane when pulling his tent trailer with a Goldwing on a gravel road at "speed" (guys couldn't catch up in a pick-up))
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A54607)
PEMBERTON...
47 ft. Portable Transfer Dock (A53117)
47 ft. Portable...
41 stump Grab Bucket (A53421)
41 stump Grab...
CAT 416B (A47477)
CAT 416B (A47477)
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
