Help w/ 55hp tractor -- New Member
   / Help w/ 55hp tractor -- New Member #1
Melton
I would appreciate some help choosing a tractor. I need to maintain 250 acres of fields. I have a dedicated backhoe. I am really looking for something to pull mowers, wagons, etc. I think I am looking for something in the 55 PTO HP range. I have bought used equipment in the past. If I can pull it off, I'd like to go with a new tractor. I hate to admit it, but I am looking for something with a nice comfortable cab.
   / Help w/ 55hp tractor -- New Member #2
Start with a dealer you like in your area, and talk to them about what you want. If no knowledge of a good dealer, then ask around or just go look at their operations - you can tell if they are busy or not, especially this time of year. If they are busy, then you can bet there is a reason. Also, look at the used and new equipment. Try to get some idea if its been there for months, or if there is good turnover of both.
If the dealer happens to be a John Deere dealer, then look at the 5000 series for the HP and the cab you want. Others will have recommendations for other brands if the dealer isn't JD.
   / Help w/ 55hp tractor -- New Member #3
Do you have a budget in mind?
Any color or manufacturer preference...?
Do you want MFWD?
What implements do you own now you want to use with it...?
   / Help w/ 55hp tractor -- New Member #4
Check out the Kioti DK65 Cab. It is a well built tractor at a good price. It is built on a 90hp drive train except it uses a 65hp Perkins Diesel. Financing is available at good rates also.
Ob1
Deere 310L (A53317)
Deere 310L (A53317)
5TH MOUNT FOR PICKUP / DOLLY (A52708)
5TH MOUNT FOR...
2012 Ford F-550 Ext. Cab Stellar EC3200 1.5 Ton Crane Utility Flatbed Truck (A55973)
2012 Ford F-550...
Mini Skid-Steer Stump Grinder (New/Unused) (A59225)
Mini Skid-Steer...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
