HELP!! Tractor not moving need to move today
   / HELP!! Tractor not moving need to move today #1
Juicybaka
Scituate, MA
Mahindra 2810
I was loading dumpster with bucket this morning and shut down went inside for a bit. Came out to start working again and tractor clutch wont engage. No sign of any type of engagement, slip.
Ive never had any problems grinding, slipping or otherwise. What should I be checking here? I pulled console cover off and see some type of little spring contact point with 4 wires on it. Could this be something to do with problem? I revved motor pumping clutch and no signs of anything. Pulled with backhoe to try to engage and nada. Please help tractor is out by end of drive. Its a Mahindra 2810 2002
Thanks,Mike
   / HELP!! Tractor not moving need to move today #2
I would start with electrical. May be a safety switch. Check fuses and look for loose/broken wires.
I am not familiar with Mahindra but seems sudden so likely electrical.
   / HELP!! Tractor not moving need to move today #4
you have probably done this but.. Check to make sure the the shuttle shift, range selector, and 1-4 gears are all in a gear. It can be easy to forget you put one in neutral, or maybe bumped one out of gear. Also we have had problems with our 1-4 gear shifter breaking at a weak point. check under the right hand side for the 1-4 gear shifter linkage and make sure everything is okay.
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
(INOP) BOMAG BW172D-2 SMOOTH DRUM ROLLER (A51247)
(INOP) BOMAG...
UNUSED FUTURE D-PDQ 45" LAND LEVELER (A51248)
UNUSED FUTURE...
1273 (A50490)
1273 (A50490)
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
JOHN DEERE 700M LOT NUMBER 34 (A53084)
JOHN DEERE 700M...
