HELP!! Tractor not moving need to move today
   / HELP!! Tractor not moving need to move today #1
Juicybaka
Scituate, MA
Mahindra 2810
I was loading dumpster with bucket this morning and shut down went inside for a bit. Came out to start working again and tractor clutch wont engage. No sign of any type of engagement, slip.
Ive never had any problems grinding, slipping or otherwise. What should I be checking here? I pulled console cover off and see some type of little spring contact point with 4 wires on it. Could this be something to do with problem? I revved motor pumping clutch and no signs of anything. Pulled with backhoe to try to engage and nada. Please help tractor is out by end of drive. Its a Mahindra 2810 2002
Thanks,Mike
   / HELP!! Tractor not moving need to move today #2
I would start with electrical. May be a safety switch. Check fuses and look for loose/broken wires.
I am not familiar with Mahindra but seems sudden so likely electrical.
   / HELP!! Tractor not moving need to move today #4
you have probably done this but.. Check to make sure the the shuttle shift, range selector, and 1-4 gears are all in a gear. It can be easy to forget you put one in neutral, or maybe bumped one out of gear. Also we have had problems with our 1-4 gear shifter breaking at a weak point. check under the right hand side for the 1-4 gear shifter linkage and make sure everything is okay.
Single Axle Rear Truck Frame (A51692)
Single Axle Rear...
Case SV185 Compact Wheel Loader Skid Steer (A51691)
Case SV185 Compact...
2023 JOHN DEERE 3033R LOT IDENTIFIER 83 (A53084)
2023 JOHN DEERE...
2017 Chevrolet Silverado 3500HD Ambulance (A52377)
2017 Chevrolet...
2019 RBR Venturi 380 (A53472)
2019 RBR Venturi...
