Help to ID pin clutch, Rhino HPHD
   / Help to ID pin clutch, Rhino HPHD #1
Anonymous Poster
Epic Contributor
I just bought a used Rhino HPHD, as-is. While testing it I got it stuck, and the driveline just started "clicking/vibrating" until engine stall. I thought the unit had shear pin driveline protection, but some research is leading me to think I may have a radial pin clutch system. Only other thing I can think of is stripped gears in the gear box.
Thought I'd try here before tearing into it to see what inside.
thanks,
   / Help to ID pin clutch, Rhino HPHD #2
Does this unit use a chain between motor and drive?
A slipping chain will give that sound.
Most hydro drives will stall motor before breaking a shear pin.
Hi Tim. No chain, just a PTO shaft from tractor to post hole digger. After un-stuck I continued to bore several more holes very smoothly, as if nothing was wrong.
   / Help to ID pin clutch, Rhino HPHD #4
Rhino PHD Yes you have a radial pin clutch, it is an option for that digger. When the clutch slipps it sounds like a machine gun going off.
   / Help to ID pin clutch, Rhino HPHD #5
I saw the HPHD (hydraulic post hole digger).
So u have a PHD, that makes a big difference.
CCI- Thanks, your photo is exactly what I've got on mt PTO connection to tractor. My lucky day I guess, since I bet the pin clutch is an extra $$ option.
Tim - Sorry for the confusion. On second review I can see how HPHD would logically stand for hydraulic. I was just reading the letters Rhino put on the side of the unit. I think HPHD stands for heavy duty post hole digger.
Thanks again!!
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
2009 INTERNATIONAL DURASTAR 4300 SBA ROAD TRACTOR (A58375)
2009 INTERNATIONAL...
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A56858)
2004 Dodge Ram...
Set of 4 12-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 12-16.5...
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
