Help to ID pin clutch, Rhino HPHD
   / Help to ID pin clutch, Rhino HPHD #1
Anonymous Poster
Epic Contributor
I just bought a used Rhino HPHD, as-is. While testing it I got it stuck, and the driveline just started "clicking/vibrating" until engine stall. I thought the unit had shear pin driveline protection, but some research is leading me to think I may have a radial pin clutch system. Only other thing I can think of is stripped gears in the gear box.
Thought I'd try here before tearing into it to see what inside.
thanks,
   / Help to ID pin clutch, Rhino HPHD #2
Does this unit use a chain between motor and drive?
A slipping chain will give that sound.
Most hydro drives will stall motor before breaking a shear pin.
Hi Tim. No chain, just a PTO shaft from tractor to post hole digger. After un-stuck I continued to bore several more holes very smoothly, as if nothing was wrong.
   / Help to ID pin clutch, Rhino HPHD #4
Rhino PHD Yes you have a radial pin clutch, it is an option for that digger. When the clutch slipps it sounds like a machine gun going off.
   / Help to ID pin clutch, Rhino HPHD #5
I saw the HPHD (hydraulic post hole digger).
So u have a PHD, that makes a big difference.
CCI- Thanks, your photo is exactly what I've got on mt PTO connection to tractor. My lucky day I guess, since I bet the pin clutch is an extra $$ option.
Tim - Sorry for the confusion. On second review I can see how HPHD would logically stand for hydraulic. I was just reading the letters Rhino put on the side of the unit. I think HPHD stands for heavy duty post hole digger.
Thanks again!!
Caterpillar Loader Quick Coupler (A53473)
Caterpillar Loader...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
5th Wheel Travel Trailer (A51694)
5th Wheel Travel...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
