Help this girl install a sound bar on Kubota
   / Help this girl install a sound bar on Kubota #11
There could already be a plug in for 12V in the back. Look real good for a 2 wire plug in back at the 3 point.
   / Help this girl install a sound bar on Kubota #12
How do I figure out if the speaker draws power when the tractor is turned off?
Sorry for the ignorant girl questions..
A good small radio/MP3 unit and a good headphone set would work alot better on a tractor without a cab.
It serve two purpose's, help protect your hearing and let you have your tunes at the same time.
   / Help this girl install a sound bar on Kubota #14
   / Help this girl install a sound bar on Kubota #15
Every tractor is going to be a little different in how the wiring is done, and where you would look for adding things. If it was me, I would go back to my dealer and ask one of the mechanics to point out on a similar tractor in the lot where he would connect the wires. While I don't have a Kubota, I have been to the dealer quite a few times for Land Pride stuff and I've found them to be very helpful when asked for assistance.
   / Help this girl install a sound bar on Kubota #16
   / Help this girl install a sound bar on Kubota #17
I bet there are 2 or 3 wires with plugs on them under the seat on that tractor. You may have a hard time getting a matching plug at somewhere besides kubota. May need to cut of the existing and replace with a plug you can match.
   / Help this girl install a sound bar on Kubota #18
I'd second the idea of ear buds or something. I use those when mowing hay. Brand I have is KOSS. They were relatively cheap (~$15) and they block out the sound well enough that I can listen even to audio books and such.
A basic DMM (digital multimeter) will include a current measuring function. You put it inline with the power cable and check the measurement while its off. If it draws more than about 10mA while "off" then it should go on a switched circuit.
   / Help this girl install a sound bar on Kubota #19
Use solder and shrink wrap for any wire splices. Cover any exposed wire with a plastic wire wrap for exposure. Use quick ties for securing. Somewhere put in an off/on switch.
   / Help this girl install a sound bar on Kubota #20
Get a decent pair of noise cancelling, blue tooth headphones. 3m makes some good ones and often have them in stock at Wally world.
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
1202 (A58374)
1202 (A58374)
2010 Volvo XC90 (A56859)
2010 Volvo XC90...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
2011 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A58017)
2011 INTERNATIONAL...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
