HELP Tension Spring Back On 60 MMM
   / HELP Tension Spring Back On 60 MMM #1
NY_Yankees_Fan
Warren County, NJ (60 miles from NYC)
Kubota BX 2200
Last fall I took the tension spring off the 60 inch MMM on the BX2200 as per the manual. I can not get it back on. /forums/images/graemlins/mad.gif What did you do to get it back on, did you use a tool? or whatever to get it back into place. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
HELP!!!
   / HELP Tension Spring Back On 60 MMM #2
Boy, these are always fun!! You'll want to use a screwdriver (or similar tool) to act as a lever to pull the spring into the hole.
I strongly suggest you have safety glasses on, by the way.
But, unless your fingers are a heck of a lot stronger then mine, use leverage of some sort. Think about where you need to stretch the spring so you pick a good "fulcrum" for the lever.
   / HELP Tension Spring Back On 60 MMM #3
If you have a snowmobile dealer near you, go there and ask him if he will sell you or let you borrow the tool that he uses to put the springs on the exhaust pipe flanges. Sled exhaust systems are held to the engine by springs that are quite stout. The tool is basically a 1/8" rod with the end formed into a "J". The other end has a Tee handle and you can exert a great pull on the spring with this tool. I have one in my toolbox and use it for a lot more than snowmobiles. it beats vise grips or levering them on with a screwdriver, hands down.
If you want to buy one, go to www.denniskirk.com and order one.
Daryl
Forage Services, L.P.
   / HELP Tension Spring Back On 60 MMM #6
Tom,
Wait until I can get a beer, come over, and watch you try to kill yourself. I know this first-hand, because I wrestled with that **** spring for about 15 minutes before I had my "D'oh" moment. /forums/images/graemlins/crazy.gif
Leave the belt off the spindle on the right side. Put the spring on (easy when there's no tension). THEN put the belt over the spindle.
It's way, way easier that way... /forums/images/graemlins/wink.gif
Thanks for the tip, got it back on, in 10 seconds! Got to LOVE TBN /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / HELP Tension Spring Back On 60 MMM #9
</font><font color="blue" class="small">( Maybe this is the one
Spring tool )</font>
I'm glad somebody found the tool in Dennis Kirk. I was out doing spring yard work. I use the tool for many other uses other than exhaust springs. It's a GREAT addition to ANY toolbox.
Daryl
   / HELP Tension Spring Back On 60 MMM #10
you know maybe instead of reading this forum I should read my manuals. I didn't take my spring off my deck hope I didn't ruin anything. /forums/images/graemlins/crazy.gif
Sterling AT (A53473)
2014 Freightliner M2 106 Altec DC47TR 47ft Digger Derrick Truck (A51692)
2014 Freightliner...
2015 Hooper T/A Trailer w/Mounted Foaming System (A53117)
2015 Hooper T/A...
2015 Kia Sedona Van (A51694)
2015 Kia Sedona...
2015 Ford Focus (A51694)
2015 Ford Focus...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
