Help! T2220 won't turn over
   / Help! T2220 won't turn over #1
NEWCOUNTRYWOMAN
Clarkston
2008 New Holland Boomer T2220
My Boomer won't turn over. Battery is good, main fuses check out, seat safety has been checked. It's almost as if the starter isn't engaging. I am not sure where to go from here. I'm afraid to start with a tear down on the starter - it worked not too long ago - I'm hoping that it will be something simple? Any suggestions?
I've gotta plow my driveway! ugh.
   / Help! T2220 won't turn over #2
Got it in neutral and pto is off? Ive done both and dtarter wont engage...
   / Help! T2220 won't turn over #3
All the safety switches need to be closed to actuate the starter solenoid that connects the battery to the starter windings. The starter is grounded through the chasis. Make sure the battery terminals are "bright and tight" and that the battery ground connection is also "bright and tight". In an emergency, and only after making sure that the tractor transmission is in neutral, you can use jumper wires from the battery to the starter directly and by pass the starter safety circuit to start the engine IF THE STARTER IS GOOD.
UNUSED FUTURE RB66 66" ROCK BUCKET (A57193)
UNUSED FUTURE RB66...
(APPROX.52) UNUSED 2X4X16 PRIME GRADE LUMBER (A57192)
(APPROX.52) UNUSED...
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2006 Caterpillar 305C CR (A53317)
2006 Caterpillar...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A57193)
UNUSED WOLVERINE...
