Help swapping engine in 267-H
/ Help swapping engine in 267-H #1
kempffc
1997 Toro Wheelhorse 267-H
Hi
I'm hoping to swap the Kohler CV17s engine in my 1997 267-H with a a B & S Intek 20HP. I'm OK with the mechanics, and it looks like a good fit, but I am having a lot of trouble trying to match up the electrics. B & S isn't offering any wiring diagrams for the engine, and the Kohler wiring diagram has several colors missing on the wires coming from the alternator. I can't even tell if I'll need to use the Kohler regulator which is mounted on the engine case, and I can't find anything similar on the B & S. Any help would be greatly appreciated.
/ Help swapping engine in 267-H #2
Have you tried calling a distributor instead of a dealer? Thats what I had to do for a Vanguard that I put on a Toro 117 Groundsmaster.
No I haven't as yet -is there one you would recommend?
/ Help swapping engine in 267-H #4
The nearest one to you.
/ Help swapping engine in 267-H #5
Hi
I recently replaced a Kohler CV18 in my 268-H with a B&S Intek 24HP....Do you still need help with this?
All the best.
Neo
2022 EZ-GO ELITE...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
2001 JOHN DEERE 310SG BACKHOE (A63276)
2001 JOHN DEERE...
Smalline 4in. Double Diaphragm S/A Towable Trash Pump (A64553)
Smalline 4in...
2016 GMC Sierra 1500 Crew Cab Pickup Truck (A64556)
2016 GMC Sierra...
