Help? STX30 won't stay running
   / Help? STX30 won't stay running #1
lrust
Easley, SC
STX30
My STX30 won't keep running. After about 5 to 10 minutes it stalls and won't restart. At times backfiring while it is running during the 5 ro 10 minutes. Have installed new spark plug, checked/cleaned air filter, made sure vent on gas cap is good. Any suggestions?
Thanks,
Lowell
   / Help? STX30 won't stay running #2
:welcome:
Fuel line filter? Spark at the plug? Old fuel? Debris in the fuel tank?
forgot to mention: replaced fuel filter, I did check spark, and have used new fuel. Did NOT check the fuel tank for debris - thanks.
   / Help? STX30 won't stay running #4
Could be a magneto problem. Sometimes they work cold but get buggy when warm.
When the engine quits grab a spark checker and see if you still have a good strong spark like when the engine is cold.
   / Help? STX30 won't stay running #5
My STX 38 with the 13 Kohler did the same thing and I went through alll of the abolve steps, but the last step solved the problem, cleaning my fuel tank.
thanks...I checked the spark last fall - I will check again. Will also clean tank. thanks!!
where is the magneto and how do I get to it if I wanted to replace it??
   / Help? STX30 won't stay running #9
Great. And thanks for the feedback. :thumbsup:
UNUSED 16" AUGER (A51248)
UNUSED 16" AUGER...
2016 Nissan Sentra Sedan (A51694)
2016 Nissan Sentra...
MacDon C3012F Corn Head (A53342)
MacDon C3012F Corn...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
(APPROX 20) 2" X 3" X 49" THICK TUBING (A51247)
(APPROX 20) 2" X...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
