Buying Advice Help Spend My Money
   / Help Spend My Money #1
Silverado21
N.A
10K Cash Budget or ~200 a month for 20K or less total package product. Raleigh NC
5.5 Acres of "flat" (10 ft change over the width of the property) land. Mostly brush and annoying small growth, some 1-3 inch trees. Wont remove anything bigger than that. There are some downed trees already that I would want to move with a grapple / FEL but I dont want to buy a big tractor just for 5 trees that I could just chainsaw smaller instead. The builder is going to clear the lot for the foundation but wont haul off the brush, that's on me to move and burn later.
Thinking about the following implements:
Bush Hog (5hp per foot from what I've researched) - Cutting down brier patches and small growth.
Tiller - Breakup the dirt, destroy brier roots and will have a garden later on
FEL possibly w/ grapple for moving brush and small growth.
And thats about it. I dont see mowing my nice lawn with the tractor since I'd imagine I'm going to end up with something fairly large and heavy. The rest of the area once cleared will be rye grass and such. Once all the brush is gone a smaller sub compact may be enough to maintain the garden and rye grass. I also know that I'll have a million more projects once I have a tractor than I can imagine now. Im thinking I want a hydrostatic unit since with the brush clearing and FEL usage im going to be going back and forth quite often. I have no aversion to buying new if the numbers make sense and theres a good selection of dealers within say 45 minutes.
I can drive and bring one home within around 12 hours of my home. There is a used L3130 that I've been looking at along with some B series units. Im thinking 20 PTO HP is about the lowest I should go but im not sure on that. I've got about a year before I'd really be itching to start working but can start anytime. Purchase will occur whenever theres a great deal on something used or a dealer offer that makes it competitive. My issue is not knowing exactly what I'm needing and not yet having enough data to know what a good deal looks like. I can see what others have sold for and get a rough idea but im not very confident in my d
Thanks everyone!
   / Help Spend My Money #2
Could you have the builder pile and burn the brush. It’s not much work to do with heavy equipment and a lot of work to do once it’s in a tangled mess with little equipment.
Could you have the builder pile and burn the brush. It痴 not much work to do with heavy equipment and a lot of work to do once it痴 in a tangled mess with little equipment.
Pile yes (Anywhere I ask within reason), Burn no. They wont burn it and I cant until the house is done for liability.
   / Help Spend My Money #4
You cant burn until the house is done? That makes no sense. When there’s no house to burn down would be way better. I’d have them pile the brush and be careful to pile tight without much dirt or you’ll have a pile that won’t burn.
It's very possible the reality will be different from what I've been told thus far by more admin staff but they said as long as they have anything on site they ask that I not burn
   / Help Spend My Money #6
Yes, something like a Kubota 'B' or 'L' series would be fine. These are in a bare tractor weight range of 1,600 pounds to 2,700 pounds and have 12" of ground clearance. You will want 12" ground clearance for tractor cultivating your garden until plants reach 12" height.
Opt for SSQA (Skid Steer Quick Attach) FEL connection so you can alternate between FEL bucket and other front attachments quickly. Consider SSQA pallet forks for moving brush, in lieu of a grapple. For 5-1/2 acres pallet forks are ample and simpler. (I like simple.) It is important to purchase Pallet Forks where fork width adjusts easily and locks securely.
VIDEO: Demonstrating a Kubota quick attach loader - YouTube
I have found these very high quality SSQA pallet forks entirely satisfactory in 50 acres of woodland and trail maintaintenance.
ETA: Small Compact Tractor and Mini Skid Steer Pallet Forks
Kubota B models have mid-PTO, so you can mow with either a MMM or a Three Point Hitch mounted Finish Mower. B's are the lightest tractors in the compact tractor category. Light enough to mow at any time.
~~MMMs are specific to tractor brands, therefore somewhat expensive.
~~Three Point Hitch mounted Finish Mowers are generic, as are all Three Point Hitch implements, therefore relatively cheap.
MOWER CHOICE: Comparing Finish Mowers (midmount VS 3-point) - Kubota B26�1 - YouTube
Kubota L models do NOT have mid-PTO, so you can only turf mow with a Three Point Hitch mounted Finish Mower.
L models with liquid filled rear tires: you will have to wait for 36 hours after a heavy rain before mowing to avoid rutting with heavy rear tires.
IMPLEMENTS: https://www.lsuagcenter.com/~/media...aa214276e14dacb/pub2917tractorimplements1.pdf
   / Help Spend My Money #7
I got a ck3510 kioti for 22500 out the door, the 26hp was 1800 less, so still over 20k. w/ loader, nothing else (no implements, trailer, etc) Zero down it's 327/mo.
Not sure how you can work that into your budget. Used had to paid for (LOL) up front - so interest on the loan, money down, etc. And no idea what issues I might be buying.
I'm using it on 25 ac horse farm, running a 6' brush hog (28.x pto hp). Most of the implements were bough used and are 5' - disks, back blade, box blade and a post hole digger. the box and digger i ran on a 17hp kubota (14 pto) and 4' hog. It weighed 1400lbs or so, the kioti 4300 is w/ loader nd filled tires. NO comparison on what it can do and how it feels to operate.
I just use forks instead of a grapple for branch moving - works fine and lots cheaper (since a front remote for the grapple can run a grand, plus the grapple..forks were $269)
A kubota B should be fine for your needs. bx a tad small, L would work too, but bigger frame might be a PITA at times. I had the kubota and the kioti at my 2 acre house property and the kioti is like a bull in a china shop. But i'm used to bx sized equipment here.
   / Help Spend My Money #8
I don't see needing a rotary cutter for such a small property. A tiller, yes, but you don't need a big machine to do that. A SCUT under 30HP should do everything you need with power left over.
And burning brush is far safer before a structure is built. If your builder doesn't want to be bothered, considering hiring someone else to do it before the builder begins.
Also, don't focus on orange when there are so many other alternatives available at better prices. I paid (am paying) about $18500 with a backhoe, loader, mower, tiller and subsoiler.
rotary cutter was more for clearing out the brush and small growth that the builder wont be clearing out for us. There are 30 year old bushes and such that I thought a rotary cutter would be best for. I used Kubota as a reference since it happens to be what I know but have no brand loyalty yet.
Yes, something like a Kubota 'B' or 'L' series would be fine. These are in a bare tractor weight range of 1,600 pounds to 2,700 pounds and have 12" of ground clearance, which you will want for cultivating your garden until plants reach 12" height.
Opt for SSQA (Skid Steer Quick Attach) FEL connection so you can alternate between FEL bucket and other front attachment quickly. Consider SSQA pallet forks for moving brush, in lieu of a grapple. For 5-1/2 acres pallet forks are ample and simpler. (I like simple.) It is important to purchase Pallet Forks where fork width adjusts easily and locks securely.
I have found these very high quality SSQA pallet forks entirely satisfactory with 50 acres of woodland and trail maintaintenance.
B's are light enough to mow at any time. MMMs are specific to tractor brands, therefore somewhat expensive. Finish mowers are generic, as are all Three Point Hitch implements, therefore relatively cheap.
Heavier L models with liquid filled rear tires, you will have to wait for 36 hours after a heavy rain before mowing.
Hadnt ever heard of or considered the forks option. Looks awesome! Thank you. I think the L is likely overkill but happens to be available locally on the used market more often than B's. Im not sold just on the one brand it just happens to be the sizes that I know and understand.
2017 BOMAG BW145D SMOOTH DRUM ROLLER (A51242)
2017 BOMAG BW145D...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
2013 JOHN DEERE 470G LC EXCAVATOR (A51242)
2013 JOHN DEERE...
Mayrath 10 x 31 Truck Auger (A50514)
Mayrath 10 x 31...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
