Help specing a hydraulic motor.
   / Help specing a hydraulic motor. #1
jeff77indy
Grantsburg, IN.
2007 4110 Mahindra w/ M112 loader.
I am contemplating a remodel of my 3 pt hitch concrete mixer to mount on my FEL using a quick attach.
What size of hydraulic motor would run this if mounted as stated and ran off either the rear remotes or possible a set of add on electric remotes?
The mixer is a chain drive off the PTO shaft.
Thanks
Jeff
   / Help specing a hydraulic motor. #2
   / Help specing a hydraulic motor. #3
These charts will get you started. Need to know the hydraulic flow of you tractor. The hydraulic psi will help determine the hp/torque.
Hydraulic
If you are using a chain and sprockets, then you will need to calculate the speed based on sprocket sizes. That is another whole level of calcualtions. If your current drum is run off the pto, then you know the motor speed will be up to 540 rpm. You will probably need a variable rate flow control if you need to change the speed of the motor.Surplus Center - SAE 12 HYD FLOW CONTROL VALVE RD112-30
Something like this may work if you use a pto now. Surplus Center - 6.15 CU IN PTO DRIVE MOTOR
Thanks for the replies and links.
The mixer I have is similar to the one dfkrug converted. So some of his calculation should work.
This will be going on my 4110 Mahindra and plan on mounting it to a bobcat type quicktach made up so the mixer can be removed and put back on the 3pt hitch and pto drive if needed.
So the hydraulic motor will be attached to the same shaft that a pto shaft would be hooked to. Not sure if I will use my rear remotes or install a electronic set of remotes.
Again thanks.
Would anyone have the specs on this Vickers HTLS motor?
P/N HMA-2096-AWO-10 1" keyed shaft, two hole flange mount.
I can't find anything by searching.
Thanks
Jeff
   / Help specing a hydraulic motor. #6
When trying to get specs for existing motors, or ones I am considering
buying, I first try to get the maker's PDF catalog. Since many listings
do not have the product ID, I have also been able to email the maker
and get specs when necessary.
My experience has shown that Char-Lynn S motors are inexpensive and
common, and the maker is helpfull. The catalogs and part #s are very
hard to decode, however. This in one reason I often look for White hyd
motors.
If you want to switch back-and-forth betw hyd motor drive and PTO
drive, you just need to buy or make the right coupling. That also
means that you have to get the correct displacement motor for the speed
you want; you can not further adjust the speed with different sprockets
like I did.
This motor was a surplus we have at work and was just wondering as it is faifly old and does not show in a search on the Vickers site.
Thanks for the link for the surplus center motor.
I need to get a count on the drive sprockets for my mixer then do some figuring.
Making a coupler isn't a problem, if I can't do it here I can at work. The PTO shaft is pined to the mixer input shaft so the coupler would be pretty straight forward.
   / Help specing a hydraulic motor. #9
That motor has 6 splines, 1 3/8 in shaft and should connect directly to a PTO shaft.
   / Help specing a hydraulic motor. #10
Surplus center also sells 6 spine, 1 3/8" pto shafts that will fit on a 1" keyed shaft. That works well if you already have a hydraulic motor that only has a keyed shaft which is much more common.
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2016 Peterbilt 320...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2024 TIMPTE HOPPER 43FT HOPPER TRAILER (A54607)
2024 TIMPTE HOPPER...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
1831 (A51247)
1831 (A51247)
2008 Ford F-450 14FT Flatbed Truck (A51692)
2008 Ford F-450...
